StreetDirectionsProperties
サマリー
Provides read and write access to street directions properties, allowing you to customize the directions output from network analysis layers. The StreetDirectionsProperties object can be read from and set on a SolverProperties object obtained through the GetSolverProperties function.
ディスカッション
The StreetDirectionsProperties object provides read and write access to street directions properties, allowing you to customize the directions output from network analysis layers.
Properties that can be read and set include language, lengthUnits, styleName, timeAttribute, and outputSpatialReference.
The StreetDirectionsProperties object is only available on route, closest facility, and vehicle routing problem network analysis layers. Additionally, the StreetDirectionsProperties object is not available on network analysis layers built on network datasets that don't support directions. A Python None object is returned if the layer is not supported.
After modifying the properties of the StreetDirectionsProperties object, the corresponding layer can be immediately used with other functions and geoprocessing tools. There is no refresh or update of the layer required to honor the changes modified through the object.
プロパティ
名前 説明 データ タイプ
enabled
(読み取り/書き込み)
Specifies whether directions will be generated when solving the layer. If directions are not needed, set this parameter to False to improve solve performance.
Boolean
language
(読み取り/書き込み)
The language in which the output text directions are written. The input for this parameter should be a two- or five-character language code representing one of the available languages for directions generation. You can retrieve a list of available language codes using the ListDirectionsLanguages function.
String
lengthUnits
(読み取り/書き込み)
Specifies the distance units used to measure lengths in the output text directions. The units must be one of the following string values:
  • Feet
  • Kilometers
  • Meters
  • Miles
  • NauticalMiles
  • Yards
String
styleName
(読み取り/書き込み)
The style of the output text directions. Different styles are available for different applications, such as printing, using on a navigation device, or routing a pedestrian. Available styles depend on the styles installed on your machine and can be checked using the ListDirectionsStyleNames function.
String
timeAttribute
(読み取り/書き込み)
The time-based network dataset cost attribute that is used to calculate the travel time in the output directions. The available timeAttribute values are a property of the network dataset. You can list the cost attributes in your network dataset using a network dataset describe object.
String
(読み取り/書き込み)
The spatial reference for the output directions feature class. Input to this attribute must be a SpatialReference object.
SpatialReference
コードのサンプル
StreetDirectionsProperties example (Workflow)
Read a route layer, set its length units to kilometers, and generate directions features.
# Name: StreetDirectionsProperties.py
# Description: Read a route layer from a layer file on disk, change the
#               directions properties, and generate directions features
# Requirements: Network Analyst extension
#Import system modules
import arcpy
try:
    #Get the route layer object from a layer file on disk
    layer_object = arcpy.mp.LayerFile(r'C:\Data\Route.lyrx').listLayers()[0]
    #Get the solver properties of the layer.
    solver_props = arcpy.na.GetSolverProperties(layer_object)
    #Get the street directions properties
    directions_props = solver_props.streetDirectionsProperties
    #Set the lengthUnits to Kilometers
    directions_props.lengthUnits = "Kilometers"
    #Set the outputSpatialReference to web mercator
    sr = arcpy.SpatialReference(3785)
    directions_props.outputSpatialReference = sr
    #Generate directions features and save them to disk.
    arcpy.na.GenerateDirectionsFeatures(layer_object,
                                        r'C:\Data\Output.gdb\RouteDirections')
    print("Script completed successfully")
except Exception as e:
    # If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    print("An error occured on line %i" % tb.tb_lineno)
    print(str(e))
