An overview of the map algebra operators
Spatial Analyst ライセンスで利用可能。
Image Analyst ライセンスで利用可能。
Map algebra supports a series of operators. The operators can be grouped into Arithmetic, Bitwise, Boolean, and Relational categories. The map algebra operators are available with the ArcGIS Spatial Analyst extension license and the ArcGIS Image Analyst extension license.
The operators are overloaded since they exist in the Spatial Analyst ArcPy module, the Image Analyst ArcPy module, and as standard operators in Python. To distinguish whether an input is a raster as opposed to a scalar variable, the input raster is cast using the Raster class: Raster("inRas"). The available operators are listed in the table below.
For operators that accept two inputs, if both inputs are scalars, the Python operator will be used to work on scalars. If one or both of the inputs are rasters (identified by casting with the Raster class), the ArcPy operator is used and will work on each cell within the rasters. For those operators that accept a single input, if it is a scalar, the Python operator is used; if a raster is input, the ArcPy operator is used.
Operators by category
The available operators are listed by category in the following table:
Map algebra operator |
Description |
Spatial Analyst geoprocessing tool |
Arithmetic |
Adds (sums) the values of two inputs. |
Multiplies each value of the input by 1. |
N/A |
Subtracts the values of one input from another. |
Negates (changes the sign) of values in the input by multiplying them by -1. |
Multiplies the values of two inputs. |
Raises the values of one input to the power of the values in the other input. |
Divides the values of two inputs. |
Performs an integer divide of two inputs. |
N/A |
Calculates the remainder (modulo) of the first input when divided by the second. |
Bitwise |
Performs a Bitwise Left Shift operation on the binary values of two inputs. |
Performs a Bitwise Right Shift operation on the binary values of two inputs. |
Boolean |
Performs a Boolean And operation on the inputs. |
Performs a Boolean-complement (Not) operation on the input. |
Performs a Boolean Or operation on the inputs. |
Performs a Boolean Exclusive Or operation on the inputs. |
Relational |
Performs a relational equal-to operation on the inputs. |
Performs a relational greater-than operation on the inputs. |
Performs a relational greater-than-equal operation on the inputs. |
Performs a relational less-than operation on the inputs. |
Performs a relational less-than-equal operation on the inputs. |
Performs a relational not-equal operation on the inputs. |
