RasterCalculator
サマリー
Provides access to all existing math functions and returns a raster object with the mathematical operation applied.
ディスカッション
For more information about how this function works, see the Raster Calculator raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
構文
RasterCalculator(rasters, input_names, expression, {extent_type}, {cellsize_type})
パラメーター 説明 データ タイプ
rasters
The list of input rasters.
Raster
input_names
The user-defined variable names.
String
expression
Build an algebraic expression to perform spatial analysis on the input raster.
String
extent_type
The spatial extent used to create the output raster.
  • FirstOf—The extent of the first raster variable
  • IntersectionOf—The minimum area common to all input rasters
  • UnionOf—The combined extent of all input rasters
  • LastOf—The extent of the last raster variable
The default value is FirstOf.
String
cellsize_type
The cell size used to create the output raster.
  • FirstOf—The cell size of the first raster variable
  • MinOf—The minimum cell size of the input rasters
  • MaxOf—The maximum cell size of the input rasters
  • MeanOf—The average cell size of the input rasters
  • LastOf—The cell size of the last raster variable
String
戻り値
データ タイプ 説明
Raster
The output raster.
コードのサンプル
RasterCalculator example 1
Example of a map algebraic expression using a raster calculator.
from arcpy.sa import *
out_rc_multi_raster = RasterCalculator(["raster1.tif", "raster2.tif"],
                                       ["x", "y"], "x*y")
out_rc_multi_raster.save("C:/arcpyExamples/raster_rc_multi.tif")
RasterCalculator example 2
# Import system modules
import arcpy
# Set the analysis environments
arcpy.env.workspace = "C:/arcpyExamples/data"
# Set local variables
in_raster1 = "raster1.tif"
in_raster2 = "raster2.tif"
# Run the RasterCalculator(Minus) function
out_rc_minus_raster = RasterCalculator([in_raster1, in_raster2], ["x", "y"],
                                       "x-y", "", "FirstOf")
# Save the output
out_rc_minus_raster.save("C:/arcpyExamples/raster_rc_minus.tif")
