RemapValue
サマリー
A list identifying what the individual input values should be reclassified to in an output raster.
RemapValue remap table for the Reclassify functions.ディスカッション
The RemapValue object can be used in the Reclassify tool and the WOTable class.
The oldValue value can be assigned to NoData by entering NoData (a string) as the newValue value.
Reclassifying individual values is usually done when the input values are categorical, for example, land use, or when changing only a few values.
構文
RemapValue(remapTable)
| 名前 | 説明 | データ タイプ |
remapTable |
The remap table to be used to remap the old values to new values. It defines a list to be used to remap the input values. It is a list of lists, with the inner lists being composed of two components. The components are:
The |
List |
プロパティ
| 名前 | 説明 | データ タイプ |
remapTable (読み取り/書き込み) |
The remap table that is used to remap the original values to new values. |
List |
コードのサンプル
Demonstrates how to create a RemapValue class and use it in the Reclassify function within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myRemapValue = RemapValue([["Water", 0], ["Wetlands", 0], ["Barrenland", 1], ["Brushtransitional", 2], ["Builtup",3]])
outReclassRV = Reclassify("landuse", "LANDUSE2", myRemapValue)
outReclassRV.save("C:/sapyexamples/output/reclassrv")
Performs a reclassification with the RemapValue class.
# Name: RemapValue_Ex_02.py
# Description: Uses the RemapValue object to run Reclassify tool.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster = "negs"
# Define the RemapValue Object
myRemapVal = RemapValue([[-3,9],[0,1],[3,-4],[4,5],[5,6],[6,4],[7,-7]])
# Run Reclassify
outReclassRV = Reclassify(inRaster, "VALUE", myRemapVal, "")
# Save the output
outReclassRV.save("C:/sapyexamples/output/reclassrevar2")
