Adjust entities
You can adjust the placement of entities you have collected or undo and redo steps you have taken during collection.
To adjust entities you have created, complete the following steps:
On the ribbon, click the tab where you added the Clearing Grids tools, and click Open Clearing Grids
.In the Adjust group, select an action you want to complete.
To move a feature, click Move
and select a feature to move it.To delete a feature, click Select
, select the desired feature, and click Delete
.To clear a selection without deleting the feature, click Clear
.To undo an action, click Undo
.To redo an action, click Redo
.To navigate the map without switching to the Map tab, click Explore
When you are finished working with Clearing Grids, in the Close group, click Close Clearing Grids
Insert a new feature into an existing sequence
You may want to insert a new feature into an existing sequence of features. To insert a new feature, complete the following steps:
In the Number/Letter Features group, from the Layer drop-down list, select the layer into which you will insert a new feature.
From the Field drop-down list, select the field storing the feature sequence.
Enter the value of the feature to be inserted in the Start/Next input box.
Click Add Number
or Add Letter
according to the type of layer you are working with.Click the map to add a feature.
If the number you entered already exists in the sequence on your map, the Clearing Grids sequence rearrange prompt appears.
Click Yes when prompted to insert the value.
Delete a feature from an existing sequence
You may want to delete a feature from an existing sequence of features. To delete a feature, complete the following steps:
In the Number/Letter Features group, from the Layer drop-down list, select the layer which you would like to delete a feature from.
In the Selection group, click Select
.Select the feature to delete.
Click Delete
.If you choose to delete a feature other than the final value in your map, the Clearing Grids sequence rearrange prompt appears.
On the prompt, click Yes to rearrange the feature sequence. Click No to skip that value in the feature sequence.
注意:
When you delete the final value in a sequence, if you want to reuse that value, you need to set the Start/Next value before using the Add Number button
or Add Letter button
