An overview of the Analysis toolset
Aviation Airports ライセンスで利用可能。
The Analysis toolset contains tools that examine, analyze, and enhance aviation content.
Tool name
Analyze Airport Features
Analyzes specified point features around an airfield to find and record information such as distance from a given runway centerline or the end of the nearest runway and its designation.
Analyze LAS Runway Obstacles
Analyzes lidar data and obstruction identification surfaces (OIS) to determine if lidar points are penetrating.
Analyze Runway Obstacles
Analyzes obstacle data and obstruction identification surfaces (OIS) to determine if obstacles are penetrating.
Generate OIS Obstacle Data
Generates a JSON string that is stored in the OBSTACLEJSON field on the input Obstruction Identification Surface (OIS) multipatch feature class. This class contains the data necessary to depict obstacles to flight safety within the approach surfaces (in the form of points, lines, or polygons) in the Terrain and Obstacle Profile layout element.
Generate OIS Profile Data
Generates a JSON string that is stored in the PROFILEJSON field on the input Obstruction Identification Surface multipatch feature class that contains the data necessary to depict the terrain, runway, and Obstruction Identification Surface (OIS) in the Terrain and Obstacle Profile layout element.
