ICAO Annex 14 Heliports (Aviation Tools)
サマリー
Generates obstruction identification surfaces (OIS) for heliports based on ICAO Annex 14 Volume II specifications.
ICAO Annex 14 Volume II defines recommended international standards and procedures for aerodromes containing heliports. This tool can be used to identify obstacles that may impact an aircraft's ability to take off from or land on a helipad. By creating multipatch or polygon features, you can visually identify obstructions in ArcGIS Pro. The OIS created by this tool should extend from a safety area around the Final Approach and Takeoff (FATO) surface. Pursuant to ICAO standards, a safety area is a defined buffer around a FATO surface that extends at least three meters out or 1/4 the diameter of the aircraft's rotor wings, whichever is greater. There must be no obstacle present inside the safety area.
使用法
  • This tool generates OIS based on three slope design categories. Slope design categories are separated by a rotor aircraft's performance class. Slope design categories will be modified by this tool whether flight operations occur during the day or night.
  • Pursuant to ICAO Annex 14 Volume II, the width of the helipad safety area should not exceed the following dimensions:
    • Seven times the rotor diameter during daytime operation
    • Ten times the rotor diameter during nighttime operation
  • The helipad safety area features you provide for the Input Safety Features parameter must be circular or rectangular.
  • To create a .json file for the Custom JSON File parameter, use the CustomizeOIS.exe utility included in the Aviation Airports Product Data download available from My Esri.
  • If you select the Curved Surface option for the Surface Shape parameter, you must provide polyline features in the Input Flight Path Features parameter for the surface to follow.
  • The Input Flight Path Features parameter value must be polyline geometry and include an ObjectID field. The polyline endpoint of the Input Flight Path Features parameter value should be created within a 100-meter search radius of the edge of the Input Safety Area Features parameter value.
  • The Input Flight Path Features parameter value can be 2D data, because the x and y-values are used to create the direction of the curve.
  • If the PATHID field is included in the Target OIS Features parameter value, it will be populated with the ObjectID value of its source Input Flight Path Feature. This allows Flight Path features to be related to their output curved approach surfaces. The PATHID field (long integer) must first be added to the Target OIS Features parameter value.
  • The unit of measurement for the Clearway Length parameter is the same as the unit of measurement for the Input Safety Area Features parameter.
  • The Input Safety Area Features parameter value should contain z-enabled polygon features with defined horizontal and vertical coordinate systems.
    注意:
    Z-values are required to determine the slope and final height of the approach surface.
  • The RunwayHelipadDesignSurface feature class in the Esri Airports Airfield dataset can be used for the Input Safety Area Features parameter value.
  • If the Input Safety Area Features parameter has values that are populated in the RUNWAYDESIGNATORIDENTIFIER and IDARPT fields, they will also be populated in corresponding fields in the Target OIS Features parameter value.
  • The ObjectIdentificationSurface_MP feature class in the Esri Airports Airspace dataset can be used for the Target OIS Features parameter value and contains the expected fields to be populated.
  • The following output attributes will be populated by the tool: USERNOTETEXT, NAME, OISSURFACETYPECODE, LANDINGSTRIPDESIGIDENTIFIER, PRIMARYSLOPEVALUE, and IDARPT.
パラメーター
ラベル 説明 データ タイプ
The input safety area around which the OIS will be generated.
Feature Layer
Target OIS Features
The target feature class that will contain the generated OIS.
Feature Layer
Surface Classification
Specifies the slope design category that will be used for the OIS.
  • Category A—Rotor aircraft operated with performance class 1 will be used.
  • Category B—Rotor aircraft operated with performance class 3 will be used.
  • Category C—Rotor aircraft operated with performance class 2 will be used.
String
Operation Type
Specifies the time when normal flight operations occur.
  • Day operation—Normal flight operations occur during the day. This is the default.
  • Night operation—Normal flight operations occur during the night.
String
Rotor Diameter
(オプション)
The rotor diameter, in meters, of aircraft using the heliport. The default is 16.5.
Double
Clearway Length
(オプション)
The length of the clearway. The unit of measurement for the clearway depends on the Input Safety Area Features parameter value.
Double
Surface Shape
(オプション)
Specifies the shape of the take off or approach surface.
  • Straight Surface—The take off climb or approach surface is straight. This is the default.
  • Curved Surface—The take off climb or approach surface is curved.
String
Approach Bearing
(オプション)
The absolute bearing that an approaching aircraft will travel along the surface. A value of 0 will align the surface to true north. The default value is 0.
Double
(オプション)
The polyline flight path features that the curved surface will follow.
Feature Layer
Heliport Elevation
(オプション)
The elevation of the highest point of the heliport. The value must be in the vertical coordinate system linear units of the target feature class. If no value is provided, the highest point of the Input Safety Area Features parameter value will be used. The default is 0.
Double
Custom JSON File
(オプション)
The import configuration, in JSON format, that will be used to create the custom OIS.
File
派生した出力
ラベル 説明 データ タイプ
Output OIS Features
The updated feature class containing the generated OIS.
Feature Layer
環境
このツールは、ジオプロセシング環境を一切使用しません。
ライセンス情報
  • Basic: No
  • Standard: Requires Airports or ArcGIS Aviation Charting
  • Advanced: Requires Airports or ArcGIS Aviation Charting
