FAA 13A Runway Protection Surfaces (Aviation Tools)
サマリー
Generates runway protection surfaces based on FAA Advisory Circular 150/5300-13A.
Safe and efficient landing and takeoff operations at an airport require that certain areas on and near the airport are clear of objects or restricted to objects with a certain function, composition, or height. These clearing standards and criteria are established to create a safer environment for the aircraft operating on or near the airport.
レガシー:
This is a deprecated tool. This functionality has been replaced by the FAA 13 Runway Protection Surfaces tool that generates runway protection surfaces based on FAA Advisory Circular AC 150/5300-13B.
使用法
  • This tool generates runway protection surfaces based on design matrices defined by the FAA. A design matrix consists of an approach category and approach design group. You can specify the design matrix to use for the surfaces by setting the Approach Category and Approach Design Group parameters.
    Some design matrices only apply to aircraft under 12,500 pounds. You can use the Small Aircraft parameter to specify the design matrix for a small aircraft.
  • The Input Runway Features parameter value must be z-enabled.
  • The Target OIS Features parameter value must be z-enabled.
  • This tool creates the runway protection area surface in an existing polygon or multipatch feature class. If a feature class is used for the Target OIS Features parameter value, it must have a vertical spatial reference. It should have Name and Description text attributes, which will be populated in the output features. Suitable Target OIS Features parameter values can be the following feature classes from the Esri Airports schema (Airports18B_NAD83_GX.xml): Airspace\ObstructionIdSurface, ObstructionIdSurface_MP, or RunwayProtectArea.
  • If the Runway End Features parameter is specified, the corresponding field values in this layer will override the values specified in the Approach Category, Aircraft Design Group, and Approach Guidance parameters. This is useful for providing specific input per runway end. The Airfield\RunwayEnd feature class is suitable input for this parameter with the following fields populated: Approach Category, Approach Guidance, and Design Group.
  • The high end of the runway refers to runway direction identifiers 19 through 36. The low end of the runway refers to runway direction identifiers 01 through 18.
  • To create a .json file for the Custom JSON File parameter, use the CustomizeOIS.exe utility included in the Aviation Airports Product Data download available from My Esri.
パラメーター
ラベル 説明 データ タイプ
The input runway dataset. The feature class must be z-enabled and contain polylines.
Feature Layer
Target OIS Features
The target feature class that will contain the generated OIS.
Feature Layer
Surface Generation
(オプション)
Specifies the type of surface that will be generated.
  • Runway Safety Area—A runway safety area (RSA) will be generated.
  • Runway Object Free Area—A runway object free area (ROFA) will be generated.
  • Runway Obstacle Free Zone—A runway obstacle free zone (ROFZ) will be generated.
  • Precision Obstacle Free Zone—A precision obstacle free zone (POFZ) will be generated.
  • Approach Runway Protection Zone—An approach runway protection zone (RPZ) will be generated.
  • Departure Runway Protection Zone—A departure runway protection zone (RPZ) will be generated.
String
Visibility Minimums
Specifies the visibility minimums that will be used for the runways.
  • Visual—Visual flight rules will be used.
  • Not lower than 1 mile—Visibility minimums will not be lower than 1 mile.
  • Not lower than 3/4 mile—Visibility minimums will not be lower than 3/4 mile.
  • Lower than 3/4 mile—Visibility minimums will be lower than 3/4 mile.
String
Approach Category
Specifies the approach category that will be used to generate surfaces.
  • A—Approach category A will be used.
  • B—Approach category B will be used.
  • C—Approach category C will be used.
  • D—Approach category D will be used.
  • E—Approach category E will be used.
String
Specifies the approach design group that will be used to generate surfaces.
  • I—Approach design group I will be used.
  • II—Approach design group II will be used.
  • III—Approach design group III will be used.
  • IV—Approach design group IV will be used.
  • V—Approach design group V will be used.
  • VI—Approach design group VI will be used.
String
Small Aircraft
(オプション)
Specifies whether surfaces will be generated with the small aircraft design matrix.
注意:
This parameter only applies when the approach_category parameter is set to A or B.
  • オン—Surfaces will be generated with the small aircraft design matrix.
  • オフ—Surfaces will not be generated with the small aircraft design matrix. This is the default.
Boolean
Approach Guidance
(オプション)
Specifies the type of approach guidance that will be used at the end of the runway.
  • Precision Category I—Precision Category I approach operations will be used for the runway.
  • Precision Category II—Precision Category II approach operations will be used for the runway.
  • Precision Category III A—Precision Category III A approach operations will be used for the runway.
  • Precision Category III B—Precision Category III B approach operations will be used for the runway.
  • Precision Category III C—Precision Category III C approach operations will be used for the runway.
  • Precision Category III D—Precision Category III D approach operations will be used for the runway.
  • Non-vertical—Nonvertical approach operations (nonprecision approach category) will be used for the runway.
  • Vertical—Vertically guided approach operations will be used for the runway.
  • Visual—Only visual approach operations will be used for the runway.
String
Runway Direction
(オプション)
Specifies the end of the runway where the approach surface will be created.
  • High end to low end—The approach surface will be created from the high end of the runway to the low end. If a displaced threshold point exists at the high end of the runway, that point will be honored when creating the OIS.
  • Low end to high end—The approach surface will be created from the low end of the runway to the high end. If a displaced threshold point exists at the low end of the runway, that point will be honored when creating the OIS.
  • Both ends—The approach surface will be created from both the low end and high end of the runway.
String
Airport Elevation
(オプション)
The highest elevation on any of the runways of the airport. The value should be in the vertical coordinate system linear units of the target feature class. If no value is provided, the highest point from the Input Runway Features parameter value will be used.
Double
Input Airport Control Point Feature
(オプション)
The point features containing an Airport Elevation parameter feature, displaced threshold features, or both. The value provided for the Airport Elevation parameter will take precedence over these point features.
Feature Layer
Runway End Features
(オプション)
The input runway end point features associated with each runway. The corresponding field values in this layer will override the values specified in the Approach Category, Aircraft Design Group, and Approach Guidance parameters.
Feature Layer
Last Low End Approach Light
(オプション)
The distance in feet of the Approach Lighting System (ALS) from the end of the low end of the runway. If no value is provided, it is assumed that there is no ALS at the low end of the runway.
Double
Last High End Approach Light
(オプション)
The distance in feet of the Approach Lighting System (ALS) from the end of the high end of the runway. If no value is provided, it is assumed that there is no ALS at the high end of the runway.
Double
Custom JSON File
(オプション)
The import configuration, in JSON format, that will be used to create the custom obstruction identification surface (OIS).
File
派生した出力
ラベル 説明 データ タイプ
Output OIS Features
The output obstruction identification surface (OIS) features.
Feature Layer
環境
このツールは、ジオプロセシング環境を一切使用しません。
ライセンス情報
  • Basic: No
  • Standard: Requires Airports or ArcGIS Aviation Charting
  • Advanced: Requires Airports or ArcGIS Aviation Charting
