FAA 13A Surfaces (Aviation Tools)
サマリー
Creates obstruction identification surfaces (OIS) based on the FAA Advisory Circular 150/5300-13A specification. These primary and approach surfaces are designed to determine which objects are vertical obstructions and are used to support planning and design activities. The type, function, and dimension of a surface differ by its runway classification. This tool creates surfaces as a polygon or multipatch features.
レガシー:
This is a deprecated tool. This functionality has been replaced by the FAA 13 tool that creates obstruction identification surfaces (OIS) based on the FAA Advisory Circular AC150/5300-13B specification.
使用法
The Input Runway Features parameter value must be z-enabled.
The Target OIS Features parameter value must be z-enabled.
This tool creates the OIS in an existing polygon or multipatch feature class. It can also be generated in an existing polygon shapefile. If a feature class is specified for the Target OIS Features parameter value, it must have a vertical spatial reference.
OIS tools are flexible and accept a variety of input and output feature class types. For more information, see the OIS Input and Output schemas.
The selection you make in the High Runway End Classification parameter and the Low Runway End Classification parameter will automatically populate most of the surface perimeters.
The Input Threshold Point Features parameter can be used to supply x-, y-, and z-geometry for displaced threshold features. If displaced thresholds are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding runway feature endpoint.
To create a
.jsonfile for the Custom JSON File parameter, use theCustomizeOIS.exeutility included in the Aviation Airports Product Data download available from My Esri.To generate clearway surfaces, check the Generate Clearway Surfaces parameter, and specify a value for the Generate Departure Surfaces parameter.
The High Runway End Classification parameter refers to runway direction identifiers 19 through 36. The Low Runway End Classification parameter refers to runway direction identifiers 01 through 18.
パラメーター
| ラベル | 説明 | データ タイプ |
Input Runway Features |
The input runway dataset. The feature class must be z-enabled and contain polylines. |
Feature Layer |
Target OIS Features |
The target feature class that will contain the generated OIS. |
Feature Layer |
High Runway End Classification |
Specifies the classification of the high end of the runway.
String |
Low Runway End Classification (オプション) |
Specifies the classification of the low end of the runway.
String |
Generate Departure Surfaces (オプション) |
Specifies whether a departure surface will be generated for departure runways.
String |
Generate Clearway Surfaces (オプション) |
Specifies whether a clearway surface will be generated for departure runways. Clearway surfaces will only be generated if a value has been specified for the
Boolean |
Input Threshold Point Features (オプション) |
The input threshold point dataset. The feature class must be z-enabled. |
Feature Layer |
Custom JSON File (オプション) |
The import configuration, in JSON format, that will be used to create the custom OIS. |
File |
派生した出力
Output OIS Features |
The updated feature class containing the generated OIS. |
Feature Layer |
環境
ライセンス情報
- Basic: No
- Standard: Requires Airports or ArcGIS Aviation Charting
- Advanced: Requires Airports or ArcGIS Aviation Charting
