ICAO Annex 15 (Aviation Tools)
サマリー
Creates obstruction identification surfaces (OIS) based on the ICAO Annex 15 specification (Areas 2a, 2b, and 2c). These surfaces assist in determining the height restriction or removal of obstacles that pose a hazard to air navigation in and around an aerodrome. This tool creates surfaces as a polygon or multipatch features.
使用法
The Input Runway Features parameter value must be z-enabled.
This tool creates the OIS in an existing polygon or multipatch feature class. The OIS can also be generated as a new polygon shapefile. If a feature class is used as the Target OIS Features parameter value, it must include a vertical spatial reference.
To create a
.jsonfile for the Custom JSON File parameter, use theCustomizeOIS.exeutility included in the Aviation Airports Product Data download available from My Esri.OIS tools are flexible and accept a variety of input and output feature class types. For more information, see the OIS Input and Output schemas.
The Input Airport Control Point Feature parameter can be used to supply x-, y-, and z-geometry for displaced threshold features. If displaced thresholds are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding runway feature endpoint.
High Runway End refers to runway direction identifiers 19 through 36. Low Runway End refers to runway direction identifiers 01 through 18.
パラメーター
| ラベル | 説明 | データ タイプ |
Input Runway Features |
The input runway dataset. The feature class must be z-enabled and contain polylines. |
Feature Layer |
Target OIS Features |
The target feature class that will contain the generated OIS. |
Feature Layer |
Length of High Runway End Clearway (オプション) |
The length of the area at the high end of the runway. The unit of measurement is based on the input runway features. |
Double |
Length of Low Runway End Clearway (オプション) |
The length of the area at the low end of the runway. The unit of measurement is based on the input runway features. |
Double |
Custom JSON File (オプション) |
The import configuration, in JSON format, that will be used to create the custom OIS. |
File |
Input Airport Control Point Feature (オプション) |
Supplies x-, y-, and z-geometry for displaced threshold features. If displaced thresholds are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding runway feature endpoint. |
Feature Layer |
派生した出力
Output OIS Features |
The updated feature class containing the generated OIS. |
Feature Layer |
環境
ライセンス情報
- Basic: No
- Standard: Requires Airports or ArcGIS Aviation Charting
- Advanced: Requires Airports or ArcGIS Aviation Charting
