Import DCDT Change File (Aviation Tools)
サマリー
Imports an NGA Digital Chart Data Transaction (DCDT) change file into an aviation geodatabase.
使用法
- An OLE DB driver for Microsoft Access is required. You can download it from the Microsoft website.
パラメーター
| ラベル | 説明 | データ タイプ |
Input DCDT Change File |
The NGA DCDT change file is a Microsoft Access |
File |
Target Geodatabase |
The Aviation charting schema workspace where the changes will be loaded. |
Workspace |
Current Cycle Date |
The date of the current charting cycle. |
Date |
派生した出力
Output Geodatabase |
The updated target workspace with changes, additions, and deletions in multiple datasets in the geodatabase. |
Workspace |
環境
このツールは、ジオプロセシング環境を一切使用しません。
ライセンス情報
- Basic: No
- Standard: Requires ArcGIS Aviation Charting
- Advanced: Requires ArcGIS Aviation Charting
