Generate Elevation Bands (Topographic Production Tools)
サマリー
Creates an elevation bands feature class from a digital elevation model (DEM).
使用法
  • The Area of Interest parameter must have only one selected feature in the map sheet extent.
  • The Hydro Exclusion Features parameter is used to identify large bodies of water and coastal areas that would significantly alter the area of the elevation bands.
  • Elevation bands are created with their limits aligned to the Contour Interval parameter value, except low and high values, which will represent their actual calculated values.
  • If more than one input raster is used, all input rasters must have the same cell size, band count, and pixel type. All input rasters should also use the same elevation units (meters or feet).
パラメーター
ラベル 説明 データ タイプ
Input Raster
The rasters that will be used to create elevation bands.
Raster Layer; Mosaic Layer
Area of Interest
The layer that will define the processing extent.
Feature Layer
Output Feature Class
The feature class containing the output elevation band features.
Feature Class
Contour Interval
Specifies the contour interval that will be used to determine the closest available contour when calculating the elevation band area.
  • 10—A contour interval of 10 will be used.
  • 20—A contour interval of 20 will be used. This is the default.
  • 40—A contour interval of 40 will be used.
  • 80—A contour interval of 80 will be used.
Long
Minimum Feature Area
The minimum area of the output polygons. Features smaller than this value will be removed. The default is 0.00016 square decimal degrees.
注意:
If you're creating an output dataset with a projected coordinate system, ensure that this value reflects the square units of that coordinate system—for example, square meters for a UTM dataset. Otherwise, the default value may result in an empty output dataset.
Double
Smoothing Tolerance
The tolerance that will be used by the smoothing algorithm. The larger the value, the more generalized the output band features. The default is 0.002 decimal degrees.
Linear Unit
(オプション)
The bodies of water that will be excluded when calculating the elevation band area.
Feature Layer
Number of Elevation Bands
(オプション)
Specifies the number of elevation bands that will be generated.
  • 1—One elevation band will be generated.
  • 2—Two elevation bands will be generated.
  • 3—Three elevation bands will be generated.
  • 4—Four elevation bands will be generated.
Long
環境
このツールは、ジオプロセシング環境を一切使用しません。
ライセンス情報
  • Basic: No
  • Standard: No
  • Advanced: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry and Spatial Analyst
