GeoNames To Geodatabase (Topographic Production Tools)
サマリー
Loads GeoNames data into a feature class and table. The feature class is composed of point features, and the table contains fields with information concerning the naming conventions used for the features. The feature class contains the Unique Feature Identifier (UFI) and Unique Name Identifier (UNI) fields, which match the same fields in the GeoNames table.
使用法
  • This tool is designed to work with downloadable files from the National Geospatial-Intelligence Agency (NGA) Geographic Names Server and defaults to the NGA GeoNames schema.
  • Before loading the GeoNames data into a database, the feature class and table must already exist.
  • If your organization has an existing GeoNames database, you can use it as long as it includes the UFI and UNI fields.
パラメーター
ラベル 説明 データ タイプ
GeoNames Source File
The path to the source file containing the GeoNames information. This must be a properly formatted GeoNames file.
Shapefile; Text File
GeoNames Feature Class Name
The GeoNames feature class. This feature class is in the working database.
Feature Class
Allow Duplicates
Specifies whether duplicate features will be imported to the GeoNames feature class.
  • オン—Features with the same geometry and attributes will be imported.
  • オフ—Features with the same geometry and attributes will not be imported. This is the default.
Boolean
GeoNames Table Name
The GeoNames table. This table is in the working database.
Table
Matching Fields
(オプション)
Specific fields in the GeoNames source file that will be mapped to fields in the GeoNames feature class and table.
値テーブル列:
  • Mapping Field—The mapping field.
  • Source Field—Fields in the GeoNames source file.
  • Target Field—Fields in the GeoNames feature class and table.
Value Table
派生した出力
ラベル 説明 データ タイプ
Out feature class
Output feature class containing GeoName features.
Feature Class
Out table
Output table containing attribution for GeoName features.
Table
環境
このツールは、ジオプロセシング環境を一切使用しません。
ライセンス情報
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
