Import MGCP Metadata (Topographic Production Tools)
サマリー
Imports Multinational Geospatial Co-production Program (MGCP) or MGCP Urban Vector Data (MUVD) metadata to an MGCP or MUVD database.
使用法
注意:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • The metadata can only be imported into an MGCP or MUVD database.
  • The input .xml files must match the MGCP or MUVD metadata specification and be compliant with MGCP or MUVD Technical Reference Documents (TRDs).
  • Data is imported into MGCP or MUVD feature classes.
パラメーター
ラベル 説明 データ タイプ
Metadata Files
The .xml files that contain the metadata that will be imported.
File
Cell or ResourceSrf Features
The Cell or ResourceSrf feature class where the metadata will be imported.
Feature Layer
Metadata Type
(オプション)
Specifies the type of metadata that will be imported.
  • MGCP—Multinational Geospatial Co-production Program metadata will be imported. This is the default.
  • MUVD—MGCP Urban Vector Data metadata will be imported.
String
派生した出力
ラベル 説明 データ タイプ
Output Cell or ResourceSrf Features
The Cell or ResourceSrf feature class that has been updated with information from the input metadata XML.
Feature Layer
環境
このツールは、ジオプロセシング環境を一切使用しません。
ライセンス情報
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
