Import Topology (Topographic Production Tools)
サマリー
Creates a geodatabase topology from a definition .xml file generated by the Export Topology tool in the Topographic Production toolbox.
Both this tool and the Export Topology tool allow you to share and create topologies within different geodatabases. The .xml file contains a definition of a topology, including feature class names, topology ranks, topology rules, and cluster tolerance.
使用法
  • This tool supports all data models, with a properly configured .xml definition file, and can be used on any feature dataset.
パラメーター
ラベル 説明 データ タイプ
Input Feature Dataset
The feature dataset in which the topology will be created. The feature dataset must contain the feature classes listed in the Input Topology Definition File.
Feature Dataset
The .xml file that contains the topology definition.
File
派生した出力
ラベル 説明 データ タイプ
Output Topology
Output topology created by importing topology rules from the topology XML file.
Topology
環境
このツールは、ジオプロセシング環境を一切使用しません。
ライセンス情報
  • Basic: No
  • Standard: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
  • Advanced: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
