Unzip MGCP Cell And Import (Topographic Production Tools)
サマリー
Unzips and imports zipped Multinational Geospatial Co-production Program (MGCP) 1-degree-by-1-degree cell packages and MGCP Urban Vector Data (MUVD) resource surface packages (.zip files) into a target geodatabase.
使用法
  • This tool recursively searches the Root Folder parameter value for .zip files. The folder must contain an MGCP cell package or MUVD resource surface package with the shapefiles and a metadata file.
  • If no shapefiles are found in the zipped package, this tool will continue to run.
  • The Target Geodatabase parameter value must be an MGCP or MUVD geodatabase and have an MGCP_Metadata or MUVD_Metadata feature dataset. The MGCP_Metadata feature dataset must contain a Cell feature class. The MUVD_Metadata feature dataset must contain a ResourceSrf feature class.
パラメーター
ラベル 説明 データ タイプ
Root Folder
The folder that contains the zipped shapefile cell or resource surface package (.zip file). This folder can contain more than one .zip file.
Folder
Target Geodatabase
The geodatabase where the unzipped shapefiles will be imported.
Workspace
派生した出力
ラベル 説明 データ タイプ
Output Geodatabase
The database where shapefiles from the Root Folder parameter value have been loaded.
Workspace
環境
Current Workspace
ライセンス情報
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
