Upload Job Files (Topographic Production Tools)
サマリー
Uploads a packaged job file to a topographic production server for further processing.
注意:
This tool is intended for use with Topographic Production workflows and is designed to be run as a step in an ArcGIS Workflow Manager workflow. Workflow Manager must be properly configured to use this tool.
使用法
  • The active portal in ArcGIS Pro must be the portal that hosts the ArcGIS Workflow Manager service and Topographic Production service items. You must sign in to ArcGIS Pro with the account that has access to both services.
  • Accounts with administrator access can upload files for any job item, and accounts without administrator access can only upload the files for their own job items.
    注意:
    The account assigned to the ArcGIS Workflow Manager Server job must be the account that created the job running on the Topographic Production service.
  • The topographic mapping job item must be paused on the server for this tool to run.
  • Job files are uploaded to the location specified in the local_job_folder extended property of the Workflow Manager job. Accounts with administrator access can update this property's value.
パラメーター
ラベル 説明 データ タイプ
Service Item
The unique name or identifier of the Workflow Manager service item on the portal with topographic production capabilities. Available Workflow Manager item options depend on the active portal in ArcGIS Pro.
String
Job Identifier
The unique name or identifier of the currently active topographic product job. Available job item options depend on the Service Item parameter value.
String
Keep Local Copy
(オプション)
Specifies whether a copy of the files will remain on the local machine.
  • オン—The local copies and a copy of the packaged file that is uploaded will remain after a successful upload.
  • オフ—The local files will be deleted after a successful upload. This is the default.
Boolean
派生した出力
ラベル 説明 データ タイプ
Updated Job Identifier
The job ID of the job with updated files.
String
環境
このツールは、ジオプロセシング環境を一切使用しません。
ライセンス情報
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
