Create an S-57 product with coverage and definitions
Доступно с лицензией ArcGIS Maritime.
If you do not have existing S-57 data, you can create the foundation for a new S-57 product by capturing a new product coverage (polygon product extent) and providing the required metadata values in the ProductDefinitions table.
Примечание:
You can also create S-57 products by importing an existing S-57 dataset.
To define the product coverage and product definitions for a new S-57 product, complete the following steps:
Start ArcGIS Pro.
Open a new or existing project.
Create a maritime geodatabase and add data to the Contents pane, if necessary.
The Maritime S-57 tab appears.
Add the ProductCoverage polygon feature class and the EditingProperties and ProductDefinitions tables to the Contents pane, if necessary.
The feature class and tables are included with the product data files.
On the Maritime S-57 tab, in the S-57 Editing group, click the Compilation Scale drop-down arrow and choose a scale.
This value represents the scale at which the chart is created. You can choose a value from the combo box list, or type a custom value. Setting a compilation scale ensures that all features that are created are attributed with the correct scale.
In the Contents pane, right-click the Editing Properties table and click Open.
In the Agency attribute column, double-click the row to access the drop-down menu and choose an agency.
The list of available agencies is generated from the IHO S-62 List of Data Producer Codes document. A new FIDS value is assigned to each record in the table by default and is used in generating a unique LNAM. The FIDS value can also be customized.
Click the Edit tab and click Create Features
.The Create Features pane appears.
In the Create Features pane, click the ProductCoverage template.
Create a polygon feature on the active map.
With the polygon feature selected, click Attributes
.The Attributes pane appears.
Примечание:
The ProductCoverage feature (subtype: ProductCoverage) must participate in one composite relationship as a child error message also appears. No action is required.
Provide a value for Dataset Name and press Enter.
The file name can be up to eight characters and can be composed of uppercase alphanumeric characters A to Z, and digits zero through nine. Typically, the first three characters are a combination of the agency code followed by the intended usage. For example, if the agency is 4E - Environmental Systems Research Institute, and the intended usage is 5 - Harbour, the file dataset name would be 4E5XXXXX in which X represents additional available characters for you to define.
Click Apply.
In the Contents pane, right-click the ProductDefinitions table and click Open.
If closed, open the Create Features pane, click the ProductDefinitions table, and click the Forward button
to open the Active Template page.
In the active template, provide the product definition-required S-57 metadata values.
The following table contains sample values:
Compilation Scale22000
Dataset Name4E4X01SW
INTU (Intended usage)Approach
Agency4E - Environmental Systems Research Institute (ESRI)
Vertical DatumMean high water springs
Sounding DatumLowest astronomical tide
Where clause((IS_CONFLATE = 1 AND PLTS_COMP_SCALE >= 1) OR ((IS_CONFLATE = 0 OR IS_CONFLATE IS NULL) AND (PLTS_COMP_SCALE >= 22000 AND PLTS_COMP_SCALE < 45000) AND NIS_PRODUCTS IN (1, 2)))Click Create after the attributes are populated.
A row is added to the ProductDefinitions table.
Ensure that the new row and the coverage polygon are selected and open the Attributes pane.
Both items should appear in the Attributes pane.
If the coverage polygon is not selected, click Select
on the Maritime S-57 tab and select it on the map.Expand the ProductCoverage node contents until ProductDefinitions appears and right-click it.
Click Add Selected To Relationship.
The product coverage polygon is linked to the product definition.
On the Edit tab, click Save, then click Yes to save all edits.
In the Selection group, click Clear to clear the selection.
You have created a product definition in the Nautical Information System (NIS).
