Rule files for building offsets
Доступно с лицензией ArcGIS Topographic Mapping.
Predefined .xml building offset rule files that can be used for cartographic production by the Apply Building Offsets tool are included in a product file installer available for ArcGIS Topographic Mapping.
The .xml files define the rules for how features are offset.
Внимание:
Modifying these files may result in errors or unexpected behavior.
The following XML example demonstrates the basic structure of a building offset rule file.
<TopographicOffsets title="MGCP_50K" version="10.2.0.0" referencescale="50000">
<AlignMarkerToStrokeOrFill>
<MarkerAlignment layer="BuildP - NotBlue072">
<Queries>
<Query>
<Symbols>
<Symbol>General Building / non-obstruction / intact / generic (point) PS-04693</Symbol>
<Symbol>General Building / non-obstruction / intact / christian (point) PS-04695</Symbol>
</Symbols>
</Query>
</Queries>
</MarkerAlignment>
<StrokeOrFill layer="AquedctL - NotBlue072">
<Queries />
</StrokeOrFill>
<SearchDistance units="Meters">25</SearchDistance>
<MarkerOrientation>PERPENDICULAR</MarkerOrientation>
</AlignMarkerToStrokeOrFill>
<Hierarchies field="HIERARCHY">
<Hierarchy layer="BuildA - Blue072" value="0">
<Queries>
<Query>
<Symbols>
<Symbol>Vertical Obstruction / single (area point) P00008</Symbol>
</Symbols>
</Query>
</Queries>
</Hierarchy>
<Hierarchy layer="LandmrkP - Blue072" value="0">
<Queries>
<Query>
<Expression>F_CODE = 'AK160'</Expression>
</Query>
<And>
<Query>
<Symbols>
<Symbol>Vertical Obstruction / single (point) PS-04512</Symbol>
</Symbols>
</Query>
</And>
</Queries>
</Hierarchy>
</Hierarchies>
<ResolveBuildingConflicts>
<Buildings>
<Building layer="BuildA - NotBlue072">
<Queries />
</Building>
<Building layer="BuildA - Blue072">
<Queries />
</Building>
</Buildings>
<HierarchyField>HIERARCHY</HierarchyField>
<InvisibilityField>ISVISIBLE</InvisibilityField>
<Barriers>
<Barrier layer="RoadL" orient="False" gap="15 Meters">
<Queries />
</Barrier>
<Barrier layer="RailrdL" orient="False" gap="15 Meters">
<Queries />
</Barrier>
</Barriers>
<BuildingGap units="Meters">20</BuildingGap>
<MinimumAllowableBuildingSize units="Meters">25</MinimumAllowableBuildingSize>
</ResolveBuildingConflicts>
</TopographicOffsets>
AlignMarkerToStrokeOrFill element
The following table provides details for each child element of the AlignMarkerToStrokeOrFill element:
Element |
Details |
The parent element with queries for the point symbols that will be aligned to nearby lines or polygons. |
The lines or polygons that the point symbols are aligned to. |
The distance in meters to search starting from the edge of the point symbol to the edge of a line or polygon. The example above uses meters as the unit of measurement, but you can specify a different unit of measurement. |
Specifies how the point symbol will be oriented relative to the line or polygon. The options are |
Подсказка:
The AlignMarkerToStrokeOrFill element defines values that are used to perform a similar function as the Align Marker To Stroke Or Fill tool. Child elements of the AlignMarkerToStrokeOrFill element are the same as the parameters of that tool.
The Queries child element of MarkerAlignment contains child elements that are used to identify the point symbols that represent building markers.
The following table provides details about the Queries child elements:
Queries
Element |
Details |
Contains the |
Contains the This element supports the following attributes:
By default, these attributes don't appear in the XML and must be inserted. Because they are undeclared, the behavior is that of a |
The point symbols that will be offset. This element supports the following attributes:
Hierarchies element
The Hierarchies element assigns Hierarchy field values to specified layers. These values prioritize layers to be offset.
<Queries>
<Query>
</Query>
<And>
<Query>
<Symbols>
</Symbols>
</Query>
</And>
</Queries>
</Hierarchy>
</Hierarchies>
The following table provides details about the Hierarchies element's child elements:
Hierarchies
Element |
Details |
The layer that the child elements will impact. The numerical value specified in this element defines the layer's priority when the Apply Building Offsets tool is run and checks the feature's offset. This can impact how the feature is symbolized. Features with a higher value are moved before features with a lower value. A feature with a value of 0 is not offset at all. In the example above, |
Contains the |
Contains the |
Expressions that limit which features are assigned hierarchy values. |
Combines multiple queries. |
Contains the |
Defines the feature symbology for a building mask according to industry specifications. You can define as many |
ResolveBuildingConflicts element
The ResolveBuildingConflicts element defines values that are used to perform a similar function as the Resolve Building Conflicts tool. Child elements of the ResolveBuildingConflicts element are the same as the parameters of that tool.
Learn more about conflict resolution and building features
<Buildings>
<Building layer="LandmrkP - NotBlue072">
<Queries>
<Query>
<And>
<Symbols>
</Symbols>
</And>
</Query>
<Or>
<Query>
<Symbols>
<Symbol>Stadium / non-obstruction / intact (point) PS-04062</Symbol>
<Symbol>Stadium / non-obstruction / not intact (point) PS-04933</Symbol>
</Symbols>
</Query>
</Or>
</Queries>
</Building>
</Buildings>
<Barriers>
<Queries />
</Barrier>
</Barriers>
The following table provides details for each child element of the ResolveBuildingConflicts element:
Element |
Details |
The child elements in this element specify the point and polygon building features that may need to be adjusted to resolve conflicts with other buildings or barriers. |
The field that will be checked for a ranking value of importance. |
The field that will be updated if a building cannot be reasonably offset from other features and as a result, will be hidden from display. |
The layers containing the linear or polygon features that conflict with buildings. |
The minimum allowable distance between building symbols at scale. Buildings that are closer together will be displaced or hidden to enforce this distance. |
The minimum allowable size of the shortest side of a rotated best-fit bounding box around the symbolized building feature drawn at the reference scale. Buildings with a bounding box side smaller than this value will be enlarged to meet it. |
The Queries grandchild element of Buildings contains child elements that are used to identify the point and polygon feature classes to check for conflicts with other buildings or barriers.
Queries
Element |
Details |
Contains the |
Contains the |
Allows multiple queries. |
The point or polygon feature symbols that will be offset. |
