Create Curved Approach (Aviation Tools)
Краткая информация
Creates curved approach obstacle identification surfaces (OIS) based on the supported specifications in ArcGIS Aviation. These curved approach surfaces are based on an input flight path and the information in the selected specification, for example, ICAO Annex 15, FAA 18B and classification. This tool creates surfaces in existing polygon or multipatch features.
Использование
  • The Input Runway Features parameter value must be z-enabled.
    Примечание:
    Z-values are required to determine the slope and final height of the approach surface.
  • The Input Flight Path Features parameter value must be polyline geometry and include an ObjectID field. The polyline endpoint of the Input Flight Path Features parameter value should be created within a 100 meter search radius of the end point of the Input Runway Features parameter value.
  • The Input Flight Path Features parameter value can be 2D data, because the x and y-values are used to create the direction of the curve.
  • To create a .json file for the Custom JSON File parameter, use the CustomizeOIS.exe utility included in the Aviation Airports Product Data download available from My Esri.
  • The surfaces generated are based on the Specification and Runway Classification parameter values.
  • The tool creates a curved approach surface in an existing polygon or multipatch feature class. If the Target OIS Features parameter value is a feature class, it must have a vertical spatial reference.
  • The starting elevation of the curved approach surface will be the same as the runway end elevation.
  • If the PATHID field is included in the Target OIS Features parameter value, it will be populated with the ObjectID value of its source Input Flight Path Feature. This allows Flight Path features to be related to their output curved approach surfaces. The PATHID field (long integer) must first be added to the Target OIS Features parameter value.
  • OIS tools are flexible and accept a variety of input and output feature class types. For more information, see the OIS Input and Output schemas.
  • When the ICAO Annex 4 Surfaces option is specified for the Specification parameter, you will have the option to create a curved takeoff climb surface or an approach surface using the Runway Classification parameter.
Параметры
Подпись Объяснение Тип данных
The input runway dataset. The feature class must be z-enabled and contain polylines.
Feature Layer
The polyline features that define curved approaches to the specified runways, terminating at the runway centerline endpoint.
Feature Layer
Target OIS Features
The target feature class that will contain the generated OIS.
Feature Layer
Specification
Specifies the approach surface specification.
  • ICAO Annex 15–The approach surface specification is ICAO Annex 15 (ETOD).
  • ICAO Annex 14–The approach surface specification is ICAO Annex 14 (OLS).
  • FAA 77–The approach surface specification is FAA regulations part 77 (FAR77).
  • FAA 18B–The approach surface specification is FAA Advisory circular 150/5300_18B (18B).
  • FAA 13–The approach surface specification is FAA Advisory circular 150/5300_13.
  • ICAO Annex 4 Surfaces–The approach surface specification is ICAO Annex 4.
String
The runway classification of the approach surface.
The Specification parameter value will determine the available options for this parameter.
String
Custom JSON File
(Дополнительный)
The import configuration, in JSON format, that will be used to create the custom OIS.
File
Threshold Offset
(Дополнительный)
A positive distance value that will be used to offset the generated approach surface outward from the runway end. The offset will be applied in the units of the input.
Double
Generate Curved Takeoff Climb Surface
(Дополнительный)
Specifies whether a curved takeoff climb surface or approach surface will be generated. This parameter is only valid when the specification parameter value is OLS.
  • Отмечено–A curved take off climb surface will be generated.
  • Не отмечено–An approach surface will be generated. This is the default.
Boolean
Производные выходные данные
Output OIS Features
The updated feature class containing the generated OIS.
Feature Layer
Параметры среды
Current Workspace
Информация о лицензировании
  • Basic: No
  • Standard: Requires Airports or ArcGIS Aviation Charting
  • Advanced: Requires Airports or ArcGIS Aviation Charting
