ICAO Annex 14 OFS OES (Aviation Tools)
Краткая информация
Creates obstacle-free surfaces (OFS) and obstacle evaluation surfaces (OES) based on ICAO Annex 14 OFS OES specifications. These surfaces define the airspace around aerodromes to be free of obstacles and safeguard airspace so flight operations can be performed safely. This tool creates surfaces as a polygon or multipatch features.
Использование
The Input Runway Features parameter must be z-enabled.
This tool creates the obstruction identification surfaces (OIS) in an existing polygon or multipatch feature class. The OIS can also be generated in an existing polygon shapefile. If a feature class is used as the Target OIS Features parameter value, it must include a vertical spatial reference.
To create a
.jsonfile for the Custom JSON File parameter, use theCustomizeOIS.exeutility included in the Aviation Airports Product Data download available from My Esri.The Input Runway End parameter uses two fields to determine the approach classification for each runway end. The approach guidance field
APPROACHGdetermines the runway classification. The design group fieldDESIGNGRwill determine the airplane design group. The runway end designator fieldRUNWAYENDDmust be populated to match the corresponding Runway End. If displaced threshold points are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding Input Runway Features parameter endpoint.The Input Airport Control Point Feature parameter can be used to supply x-, y-, and z-geometry for the Airport Elevation parameter.
The horizontal surface generated by this tool will be continuous across the multipatch feature.
Параметры
| Подпись | Объяснение | Тип данных |
Input Runway Features |
The input runway dataset. The feature class must be z-enabled and contain polylines. |
Feature Layer |
Target OIS Features |
The target feature class that will contain the generated OIS. |
Feature Layer |
Input Runway (Дополнительный) |
The input runway feature layer. The |
Feature Layer |
Input Runway End (Дополнительный) |
The input runway end feature layer. The approach guidance field |
Feature Layer |
Input Airport Control Point Feature (Дополнительный) |
Supplies x-, y-, and z-geometry for displaced threshold features. If displaced thresholds are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding runway feature endpoint. |
Feature Layer |
Custom JSON File (Дополнительный) |
The import configuration, in JSON format, that will be used to create the custom OIS. |
File |
Include Merged Surfaces (Дополнительный) |
Specifies whether merged surfaces will be generated.
Boolean |
Производные выходные данные
Output OIS Features |
The output feature class with the output OIS features. |
Feature Layer |
Параметры среды
Этот инструмент не использует параметры среды геообработки.
Информация о лицензировании
- Basic: No
- Standard: Requires Airports or ArcGIS Aviation Charting
- Advanced: Requires Airports or ArcGIS Aviation Charting
