ICAO Annex 15 (Aviation Tools)
Краткая информация
Creates obstruction identification surfaces (OIS) based on the ICAO Annex 15 specification (Areas 2a, 2b, and 2c). These surfaces assist in determining the height restriction or removal of obstacles that pose a hazard to air navigation in and around an aerodrome. This tool creates surfaces as a polygon or multipatch features.
Использование
  • The Input Runway Features parameter value must be z-enabled.
  • This tool creates the OIS in an existing polygon or multipatch feature class. The OIS can also be generated as a new polygon shapefile. If a feature class is used as the Target OIS Features parameter value, it must include a vertical spatial reference.
  • To create a .json file for the Custom JSON File parameter, use the CustomizeOIS.exe utility included in the Aviation Airports Product Data download available from My Esri.
  • OIS tools are flexible and accept a variety of input and output feature class types. For more information, see the OIS Input and Output schemas.
  • The Input Airport Control Point Feature parameter can be used to supply x-, y-, and z-geometry for displaced threshold features. If displaced thresholds are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding runway feature endpoint.
  • High Runway End refers to runway direction identifiers 19 through 36. Low Runway End refers to runway direction identifiers 01 through 18.
Параметры
Подпись Объяснение Тип данных
The input runway dataset. The feature class must be z-enabled and contain polylines.
Feature Layer
Target OIS Features
The target feature class that will contain the generated OIS.
Feature Layer
Length of High Runway End Clearway
(Дополнительный)
The length of the area at the high end of the runway. The unit of measurement is based on the input runway features.
Double
Length of Low Runway End Clearway
(Дополнительный)
The length of the area at the low end of the runway. The unit of measurement is based on the input runway features.
Double
Custom JSON File
(Дополнительный)
The import configuration, in JSON format, that will be used to create the custom OIS.
File
(Дополнительный)
Supplies x-, y-, and z-geometry for displaced threshold features. If displaced thresholds are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding runway feature endpoint.
Feature Layer
Производные выходные данные
Output OIS Features
The updated feature class containing the generated OIS.
Feature Layer
Параметры среды
Current Workspace
Информация о лицензировании
  • Basic: No
  • Standard: Requires Airports or ArcGIS Aviation Charting
  • Advanced: Requires Airports or ArcGIS Aviation Charting
