Add Field Based Suitability Criteria (Business Analyst Tools)
Краткая информация
Adds criteria based on the numerical fields existing in the input layer.
Использование
The input analysis layer can be created by the Make Suitability Analysis Layer tool.
Set the influence for each criteria using the Set Criteria Property tool.
Параметры
| Подпись | Объяснение | Тип данных |
Input Suitability Analysis Layer |
The Suitability Analysis layer that will be used in the analysis. |
Feature Layer; Group Layer |
Fields |
The numeric fields from which the suitability criteria will be determined. |
String |
Производные выходные данные
Output Suitability Analysis Layer |
The name of the Suitability Analysis layer that will be added to the map. |
Output Criteria Name |
The name of the criteria that will be added to the Suitability Analysis layer. |
String |
Параметры среды
Информация о лицензировании
- Basic: Requires Business Analyst
- Standard: Requires Business Analyst
- Advanced: Requires Business Analyst
