Set Target Site (Business Analyst Tools)
Краткая информация
Adds a target site to a Suitability Analysis group layer.
A target site is typically a trade area around a high-performing location, such as a store or clinic. Criteria values in the target site are used to score candidate sites that are closest in value to the target site.
Использование
  • The suitability analysis scoring influence defaults to target when a target site is set.
  • The target influence sets the target site's value as the highest score for each criterion.
  • The candidate site with criteria values closest to the target site will receive the highest score.
  • When a target site is set, a candidate site's value for each criterion is compared to the corresponding Target Site Layer parameter value.
  • You can replace the target site by rerunning this tool with a different Target Site Feature ID parameter value.
  • The target influence can only be enabled by setting a target site.
  • Selected records in the Target Site layer define the Target Site Feature ID parameter options.
  • Selecting a record in the Target Site Layer parameter value will set it as the Target Site Feature ID parameter value by default.
Параметры
Подпись Объяснение Тип данных
Input Suitability Analysis Layer
The Suitability Analysis layer that will be used in the analysis.
Group Layer; Feature Dataset
Target Site Layer
(Дополнительный)
The layer that contains the target site.
Feature Layer
(Дополнительный)
The feature from the target site layer that will be added to the group layer as the target site.
String
Производные выходные данные
Output Suitability Analysis Layer
The name of the Suitability Analysis layer that will be added to the analysis.
Group Layer
Параметры среды
Current Workspace
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
