Add Territory Seed Points (Territory Design Tools)
Краткая информация
Creates a point feature that is used to determine the starting point for creating territories.
Использование
  • Seed points can be point locations from franchise addresses, sales offices, or distribution centers and are a common method for creating territories.
  • Seed points are used as the starting point for creating territories but do not necessarily represent the center of the territories.
    Seed points and territory centers
    Pins represents seed points. Squares represents territory centers.
Параметры
Подпись Объяснение Тип данных
Input Territory Solution
The Territory Design solution dataset.
Group Layer; Feature Dataset; String
Level
The target territory level for which the seed points feature will be created.
String
Input Seed Point Features
The points feature layer that represents seed points for territories.
Feature Layer
Field Map
(Дополнительный)
Specifies the attributes and fields that will be used for the seed point properties.
The field value associated with the Type attribute can only be Required or Candidate.
Столбцы таблицы значений:
  • Attribute–The attributes that will be used for the seed point properties.
    • Name–The name for a seed point feature
    • ID–The ID for a seed point feature
    • Type–The seed point type
  • Field–The fields that will be used for the seed point properties.
Value Table
Append to Existing Seed Points
(Дополнительный)
Specifies whether the data will be appended or replaced.
  • Отмечено–The data will be appended.
  • Не отмечено–The data will be replaced. This is the default.
Boolean
Производные выходные данные
Updated Territory Solution
The updated territory solution.
Group Layer
Параметры среды
Current Workspace
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
