Generate Territory Report (Territory Design Tools)
Краткая информация
Creates a summary report of a territory solution or a comparison report of two solutions.
Использование
  • The Territory Solution should contain at least one level variable.
  • A report can be created for an individual level or all levels.
Параметры
Подпись Объяснение Тип данных
Input Territory Solution
The input territory solution for the report.
Group Layer; Feature Dataset; String
Level
Specifies the territory level that will be used to create the report.
  • All Levels–All territory levels will appear in the report.
String
Report Type
(Дополнительный)
Specifies the type of report that will be generated.
  • Territory Summary–The report will contain a summary of a territory solution, such as hierarchy and statistics. This is the default.
  • Compare Territories–The report will compare two territory solutions.
  • Realignment–The report will contain a summary realignment report for the territories.
  • Realignment Detailed–The report will contain a list of the reassigned features.
String
Output Report Folder
(Дополнительный)
The output location where the report will be saved.
Folder
Report Title
(Дополнительный)
The title of the report.
String
Report Output Formats
(Дополнительный)
Specifies the format of the output report.
  • PDF–The report will be in PDF format. This is the default.
  • XLSX–The report will be in XLSX format.
  • HTML–The report will be in HTML format.
  • ZIP–The report will be in ZIP format.
  • CSV–The report will be in CSV format.
String
Comparison Territory Solution
(Дополнительный)
The territory solution for the comparison report.
Comparison Level
(Дополнительный)
Specifies the territory level that will be used for the comparison or realignment report.
  • All Levels–All territory levels will be used for the comparison or realignment report.
String
Производные выходные данные
Output Report
The output report file.
File
Параметры среды
Current Workspace
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
