Set Balance Variables (Territory Design Tools)
Краткая информация
Configures variables to be used in the balancing process.
Использование
  • The variables will be used according to relative weight, which is calculated based on a specified preference for each variable.
  • Preference refers to the relative weight of each variable.
  • Preferences from all of the variables must total 100 percent.
  • Set the Balance Variables parameter weight value to zero if you want to disable the variable when balancing.
Параметры
Подпись Объяснение Тип данных
Input Territory Solution
The name of the input territory solution.
Group Layer; Feature Dataset; String
Level
The name of the level to which the calculated field will be added.
String
Balance Variables
The variables that will be used in the balance process.
Столбцы таблицы значений:
  • Variable–The defined input.
  • Weight–The amount of influence a given variable has in the analysis.
Value Table
Производные выходные данные
Updated Territory Solution
The updated territory solution.
Group Layer
Параметры среды
Этот инструмент не использует параметры среды геообработки.
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
