Validate Territories (Territory Design Tools)
Краткая информация
Validates a territory solution for invalid territories.
Использование
  • Run this tool after manually editing the territory solution. Any violations will need to be reviewed and resolved manually.
  • Validation issues will be included in the tool messages and added to the Territory Validation Errors field or Feature Validation Errors field.
  • Territory validation issues will be displayed in the Territory Validation Errors field.
  • The Feature Validation Errors field will display features that contain validation issues for a territory.
  • The tool will analyze the territory solution for the following errors:
    • Barriers violation
    • Buffer distance constraint violation
    • Minimum attribute constraint limit violation
    • Maximum attribute constraint limit violation
    • Minimum distance between centers constraint violation
    • Maximum territory radius constraint violation
    • Territory is empty
    • Territory center is undefined
    • Territory is not contiguous
    • Territory has holes
    • Territory name is not unique
Параметры
Подпись Объяснение Тип данных
Input Territory Solution
The territory solution that will be validated.
Group Layer; Feature Dataset; String
Level
The level that will be analyzed in the validation.
String
Производные выходные данные
Updated Territory Solution
The territory solution output.
Group Layer
Параметры среды
Этот инструмент не использует параметры среды геообработки.
Информация о лицензировании
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
