Download Job Files (Topographic Production Tools)
Краткая информация
Downloads and extracts the latest version of the job files from a topographic production server for manual operations.
Внимание:
This tool is intended for use with Topographic Production workflows and is designed to be run as a step in an ArcGIS Workflow Manager workflow. Workflow Manager must be properly configured to use this tool.
Использование
  • The active portal in ArcGIS Pro must be the portal that hosts the ArcGIS Workflow Manager service and Topographic Production service items. You must sign in to ArcGIS Pro with the account that has access to both services.
  • Accounts with administrator access can download files for any job item, and accounts without administrator access can only download the files for their own job items.
    Примечание:
    The account assigned to the ArcGIS Workflow Manager Server job must be the account that created the job running on the Topographic Production service.
  • The topographic mapping job item must be paused on the server for this tool to run.
  • Job files are uploaded to the location specified in the local_job_folder extended property of the Workflow Manager job. Accounts with administrator access can update this property's value.
Параметры
Подпись Объяснение Тип данных
Service Item
The unique name or identifier of the Workflow Manager service item on the portal with topographic production capabilities. Available Workflow Manager item options depend on the active portal in ArcGIS Pro.
String
Job Identifier
The unique name or identifier of the currently active topographic product job. Available job item options depend on the Service Item parameter value.
String
Производные выходные данные
Output Job Location
The output location where the job files will be downloaded and extracted on the local machine.
Folder
Параметры среды
Этот инструмент не использует параметры среды геообработки.
Информация о лицензировании
  • Basic: No
  • Standard: Requires Topographic Mapping
  • Advanced: Requires Topographic Mapping
