Export Topology (Topographic Production Tools)
Краткая информация
Exports a topology from a geodatabase to an .xml file.
The .xml file contains a definition of a topology, including feature class names, topology ranks, topology rules, and cluster tolerance, and can be used by the Import Topology tool to recreate a topology in a new feature dataset.
Использование
- This tool supports all data models and can be used on any geodatabase topology.
Параметры
| Подпись | Объяснение | Тип данных |
Input Topology |
An existing topology in a geodatabase. All feature classes that participate in this topology will be listed in the output |
Topology; Topology Layer |
Topology XML Document Location |
The folder in which the |
Folder |
Topology XML Document Name |
The name of the topology |
String |
Производные выходные данные
Output Topology XML Document |
Output topology XML file created by exporting topology rules. |
File |
Параметры среды
Этот инструмент не использует параметры среды геообработки.
Информация о лицензировании
- Basic: No
- Standard: Requires Topographic Mapping
- Advanced: Requires Topographic Mapping
