Unzip MGCP Cell And Import (Topographic Production Tools)
Краткая информация
Unzips and imports zipped Multinational Geospatial Co-production Program (MGCP) 1-degree-by-1-degree cell packages and MGCP Urban Vector Data (MUVD) resource surface packages (.zip files) into a target geodatabase.
Использование
This tool recursively searches the Root Folder parameter value for
.zipfiles. The folder must contain an MGCP cell package or MUVD resource surface package with the shapefiles and a metadata file.If no shapefiles are found in the zipped package, this tool will continue to run.
The Target Geodatabase parameter value must be an MGCP or MUVD geodatabase and have an MGCP_Metadata or MUVD_Metadata feature dataset. The MGCP_Metadata feature dataset must contain a Cell feature class. The MUVD_Metadata feature dataset must contain a ResourceSrf feature class.
Параметры
| Подпись | Объяснение | Тип данных |
Root Folder |
The folder that contains the zipped shapefile cell or resource surface package ( |
Folder |
Target Geodatabase |
The geodatabase where the unzipped shapefiles will be imported. |
Workspace |
Производные выходные данные
Output Geodatabase |
The database where shapefiles from the Root Folder parameter value have been loaded. |
Workspace |
Параметры среды
Информация о лицензировании
- Basic: No
- Standard: Requires Topographic Mapping
- Advanced: Requires Topographic Mapping
