向 Terrain 添加要素类 (3D Analyst 工具)
汇总
向 terrain 数据集添加一个或多个要素类。
用法
  • 输入要素必须与 Terrain 数据集位于同一要素数据集中。
  • Terrain 数据集必须已定义一个或多个金字塔等级。
  • 根据 terrain 中添加的与要素关联的表面类型,可能需要使用 构建 Terrain 重新构建 terrain 数据集。 ArcCatalog 中 terrain 数据集的属性对话框和 ArcMap 中 terrain 图层的属性对话框均提供了是否需要重新构建数据集的指示。
  • 仅当要素包含简化几何且针对预期显示比例具有视觉相关性时,才考虑启用隔断线和面表面要素类型的概览选项。 例如,在概览显示中,隔断线可能不够明显以至于无关紧要,而裁剪面则很有用。 如果存在详细边界要素,请考虑对其进行概化,并在概览中使用较粗略的制图表达。 应在更适合细节分辨率的显示比例下使用详细版本。
  • 对于在企业级地理数据库中存储的 terrain 数据集:
    • 目标 terrain 数据无法注册为版本化。
    • 输入要素类无法注册为版本化。
参数
标注 说明 数据类型
输入 Terrain
要添加要素类的 terrain。 terrain 数据集必须已创建一个或多个金字塔等级。
Terrain Layer
输入要素类
识别要添加至 terrain 的要素。 每个要素必须位于 terrain 所在的要素数据集中,并且其角色通过以下属性定义:
值表列:
  • Input Features—Name of the feature class being added to the terrain.
  • Height Field—Field containing the feature's height information.
  • Type—The way the input future contributes to the terrain surface.
    • Mass Points—Points that are used for triangulation.
    • Hard Line—Linear features that represent sharp discontinuities in elevation.
    • Soft Line—Linear features that represent a gradual discontinuity in elevation.
    • Hard Clip—Polygon feature that defines the interpolation zone with sharp discontinuities at the edges.
    • Soft Clip—Polygon feature that defines the interpolation zone with gradual discontinuities at the edges.
    • Hard Erase—Polygon feature that defines the area to be treated as having no data. The hard designation indicates the boundary of the polygon represents a sharp discontinuity.
    • Soft Erase—Polygon feature that defines the area to be treated as having no data. The soft designation indicates the boundary of the polygon represents a gradual discontinuity.
    • Hard Replace—Polygon feature that defines a constant z-value for all mass points within the boundary. The hard designation indicates the boundary of the polygon represents a sharp discontinuity.
    • Soft Replace—Polygon feature that defines a constant z-value for all mass points within the boundary. The soft designation indicates the boundary of the polygon represents a gradual discontinuity.
    • Hard Value Fill—Polygon feature that defines a constant z-value within its boundary. The hard designation indicates the boundary of the polygon represents a sharp discontinuity.
    • Soft Value Fill—Polygon feature that defines a constant z-value within its boundary. The soft designation indicates the boundary of the polygon represents a gradual discontinuity.
  • Group—Defines the group of each contributing feature.
  • Min Resolution—The lowest resolution that the surface feature will be enforced.
  • Max Resolution—The highest resolution that the surface feature will be enforced.
  • Overview—Indicates whether the feature is enforced at the coarsest representation of the terrain dataset.
  • Embed—Checking this option indicates the source features will be copied to a hidden feature class that will be referenced by and only available to the terrain.
  • Embed Name—Name of the embedded feature class.
  • Embed Fields—Specifies Blob field attributes to be retained in the embedded feature class.
  • Anchor—Specifies whether the point feature class will be anchored through all terrain pyramid levels.
Value Table
派生输出
标注 说明 数据类型
更新后的输入 Terrain
更新后的 Terrain。
Terrain Layer
环境
当前工作空间, 自动提交
许可信息
  • 基本: 需要 3D Analyst
  • 标准: 需要 3D Analyst
  • 高级: 需要 3D Analyst
