arcpy.3d.DeleteTerrainPoints(in_terrain, data_source, polygon_features_or_extent)
名称
说明
数据类型
in_terrain
要处理的地形数据集。
Terrain Layer
data_source
[data_source,...]
点将被移除的一个或多个要素类。
String
指定将从中移除点的区域。 可使用面要素类或范围。
如果需要范围值,使用 arcpy.Extent 对象。
Feature Layer; Extent
派生输出
名称
说明
数据类型
derived_out_terrain
更新后的 Terrain。
Terrain Layer
代码示例
DeleteTerrainPoints 示例 1(Python 窗口)
下面的示例演示了如何在 Python 窗口中使用此工具:
arcpy.env.workspace = "C:/data"
arcpy.ddd.DeleteTerrainPoints("sample.gdb/featuredataset/terrain",
"mass_pts_embed", "1379938 235633 1382756 237681")
DeleteTerrainPoints 示例 2(独立脚本)
下面的示例演示了如何在独立 Python 脚本中使用此工具:
Name: Delete Terrain Outliers
Description: Uses Locate Outliers to identify outlier points in
a terrain dataset, and eliminates the outliers from the
terrain with Delete Terrain Points.
# Import system modules
import arcpy
# Set Local Variables
arcpy.env.workspace = 'C:/data'
terrain = 'test.gdb/featuredataset/sample_terrain'
terrainPt = 'elevation_pts' # name of terrain point data source
outliers = 'in_memory/outliers'
# Run LocateOutliers
arcpy.ddd.LocateOutliers(terrain, outliers, 'APPLY_HARD_LIMIT', -10,
350, 'APPLY_COMPARISON_FILTER', 1.2, 120,
0.8, 8000)
# Run Delete Terrain Points
arcpy.ddd.DeleteTerrainPoints(terrain, terrainPt, outliers)
