Assign Customers By Distance (Business Analyst Tools)
汇总
Assigns customers to the closest store based on a selected distance type.
用法
  • The ID of the closest store is assigned to each customer. Store assignments are influenced by the selected value for Distance Type.
  • An Origin-Destination matrix calculates the least-cost paths between customers and stores using the Business Analyst network dataset and routing service.
  • When using a network distance type, you can adjust the Search Tolerance parameter value to define the maximum distance the input customer features can be from a road. Customer points beyond this distance will not receive a store assignment.
  • If a store cannot be assigned to a customer point, the new Store ID value will be null and the Distance value will contain a -1.
参数
标注 说明 数据类型
Input Customer Features
The input point feature layer representing customers.
Feature Layer
Input Store Features
The input point feature layer representing store or facilities.
Feature Layer
Store ID Field
A unique ID field for Input Store Features.
Field
Output Feature Class
A point layer containing customers with assigned store or facility and distance.
Feature Class
Field Name
(可选)
A new field that contains the assigned store or facility ID.
String
Distance Type
(可选)
The method of travel used to calculate the distance between customers and stores.
String
Distance Units
(可选)
The units that will be used to measure the selected distance type.
String
Travel Direction
(可选)
Specifies the direction of travel that will be used between stores or facilities and customers.
  • Toward Stores—The direction of travel will be from customers to stores. This is the default.
  • Away from Stores—The direction of travel will be from stores to customers.
String
Time of Day
(可选)
The time and date that will be used when calculating distance.
Date
Time Zone
(可选)
Specifies the time zone that will be used for the Time of Day parameter.
  • Time Zone at Location—The time zone in which the territories are located will be used. This is the default.
  • UTC—Coordinated universal time (UTC) will be used.
String
Search Tolerance
(可选)
The maximum distance that input points can be from the network. Points located beyond the search tolerance will be excluded from processing.
The parameter requires a distance value and units for the tolerance. The default value is 5000 meters.
Linear Unit
环境
Current Workspace, Data Source, Network Source
许可信息
  • 基本: Requires Business Analyst and Network Analyst
  • 标准: Requires Business Analyst and Network Analyst
  • 高级: Requires Business Analyst and Network Analyst
