Generate Survey Report For Profile (Business Analyst Tools)
汇总
Displays characteristics from the consumer survey data for your target profile to determine customer lifestyle habits and preferences.
用法
  • A report is generated for all the characteristics from the selected Survey Category parameter value.
  • The generated report is based on the Target Profile parameter value compared to a base profile.
  • Reports can be sorted using the Sort Column parameter's Expected Number or Index options. Expected Number is based on counts, for example, number of adults, and Index is based on a rank.
参数
标注 说明 数据类型
Target Profile
A segmentation profile representing the segments that will be analyzed. The target profile typically represents your customer segmentation profile.
File
Base Profile
A segmentation profile representing the base profile segments. This is the segmentation used for comparison. The base profile typically represents your market area segmentation profile.
File
Survey Category
A category that contains characteristics from the consumer survey.
String
Output Report Folder
The output location where the report will be saved.
Folder
Sort Column
(可选)
Specifies the column that will be used to sort the report.
  • Expected Number—The report will be sorted based on counts—for example, number of adults. This is the default.
  • Index—The report will be sorted based on rank.
String
Sort Order
(可选)
Specifies the order of the report, based on the sort column, in ascending or descending order.
  • Ascending—The report will be sorted in ascending order.
  • Descending—The report will be sorted in descending order. This is the default.
String
Report Title
(可选)
The title of the report.
String
Report Formats
(可选)
Specifies the format of the output report.
  • PDF—The report will be in PDF format. This is the default.
  • XLSX—The report will be in XLSX format.
  • HTML—The report will be in HTML format.
  • CSV—The report will be in CSV format.
  • PAGX—The report will be in PAGX format.
String
派生输出
标注 说明 数据类型
Output Report
The output report file.
File
环境
Current Workspace, Data Source, Display Segment Names
许可信息
  • 基本: Requires Business Analyst
  • 标准: Requires Business Analyst
  • 高级: Requires Business Analyst
