Import Segmentation Profile (Business Analyst Tools)
汇总
Generates a segmentation profile from a table.
用法
  • Optimally, the input table should contain the Segment ID, Segment Name, Count, and Percent fields. If the table was built with volumetric data, the Total Volume and Average Volumetric fields should also be included.
    Import segmentation table
    提示:
    Remove any additional fields that exist in the input table before importing it.
  • The Segment ID and Count fields are required in the input table.
  • The Segment ID field values in the input table must exist in the active Business Analyst dataset.
    The input table must be in a tabular format supported by ArcGIS Pro. Supported formats include the following:
    • Geodatabase
    • Database
    • Feature layer attribute table
    • dBASE
    • Microsoft Excel
    • Text, ASCII, and comma-separated values files (.csv)
    If the Segment Name field does not exist in the input table, it will be added during the import process. The new field will be populated with values based on correlation to the Segment ID field.
    If only a subset of Segment ID values are included in the input table, the balance of the full distribution of segments will be added during processing. The Count and Percent fields for these additions will be zero filled.
参数
标注 说明 数据类型
Input Table
The input table with segmentation information.
Table View
Segmentation Base
The segmentation base for the profile being created. Available options are provided by the segmentation dataset in use.
String
Output Profile
The name of the segmentation file that will be created.
File
Segment ID Field
A string field that contains the segmentation code.
Field
Count Field
A numeric field that contains segment count information.
Field
Total Volume Field
(可选)
A numeric field that contains volume information.
Field
环境
Current Workspace, Data Source, Display Segment Names
许可信息
  • 基本: Requires Business Analyst
  • 标准: Requires Business Analyst
  • 高级: Requires Business Analyst
