Remove Overlap (multiple) (Business Analyst Tools)
汇总
Removes overlap between polygons contained in multiple input layers.
插图
Remove Overlap tool illustration
用法
  • The Output Feature Class parameter contains the input polygons with overlap removed.
  • If no overlap exists between the input polygons, the output feature class will be a copy of the input.
参数
标注 说明 数据类型
Input Features
The input features containing the overlapping polygons.
Value Table
The feature class containing the new trade area features.
Feature Class
Method
(可选)
Specifies how the overlap between trade areas will be removed.
  • Center Line—Overlap will be removed by creating a border that evenly distributes the overlapping area between polygons. This is the simplest method. This is the default. Center Line
  • Thiessen—Overlap will be removed using straight lines to divide the area of intersection. This method uses a series of geometric functions to create nonoverlapping trade areas. Thiessen
  • Grid—Overlap will be removed by creating a grid of parallel lines used to define a natural division between polygons. Grid
String
Attributes To Join
(可选)
Specifies the attributes of the input layers that will be transferred to the output.
  • All attributes—All attributes from the input features will be transferred to the output feature class. This is the default.
  • All attributes except feature IDs—All attributes from the input features, except the FID field, will be transferred to the output feature class.
  • Only feature IDs—Only the FID field from the input features will be transferred to the output feature class.
String
环境
Current Workspace
许可信息
  • 基本: Requires Business Analyst
  • 标准: Requires Business Analyst
  • 高级: Requires Business Analyst
