Quick Export (Data Interoperability Tools)
汇总
Converts one or more input feature classes or feature layers into any format supported by the ArcGIS Data Interoperability extension.
用法
  • This tool is used to either export data from ArcGIS or as the final step in a model or script when the destination data is nonnative to ArcGIS.
  • This tool creates a default output schema for the output format. If the output requires schema changes, consider using Spatial ETL tools.
  • This tool does not honor the Allow geoprocessing tools to overwrite existing datasets option.
  • Although this tool is most commonly used to create non-Esri data formats, it can also create native Esri formats.
  • Any Bézier curves in the input will be maintained as Bézier curves in the output.
参数
标注 说明 数据类型
Input Layer
The feature layers or feature classes that will be exported.
Feature Layer
Output Dataset
(可选)
The format and dataset to which the data will be exported.
Interop Destination Dataset
环境
Current Workspace, Scratch Workspace
许可信息
  • 基本: Requires Data Interoperability
  • 标准: Requires Data Interoperability
  • 高级: Requires Data Interoperability
