arcpy.management.ComputePansharpenWeights(in_raster, in_panchromatic_image, {band_indexes})
名称
说明
数据类型
in_raster
具有全色波段的多光谱栅格。
Mosaic Dataset; Mosaic Layer; Raster Dataset; Raster Layer
与多光谱栅格相关联的全色波段。
Raster Layer
band_indexes
(可选)
全色锐化权重的波段顺序。
如果将栅格产品用作 in_raster 参数,则应用栅格产品模板中的波段顺序。
String
派生输出
名称
说明
数据类型
out_string
输出全色锐化权重。
String
代码示例
ComputePansharpenWeights 示例 1(Python 窗口)
这是 ComputePansharpenWeights 工具的 Python 示例。
import arcpy
"c:/data/rgb.tif", "c:/data/image.tif", "3 2 1 4")
ComputePansharpenWeights 示例 2(独立脚本)
这是 ComputePansharpenWeights 工具的 Python 脚本示例。
#Run Compute Pan Sharpen Weights tool using the bands 4,3,2,1
import arcpy
InMSraster = "C:\\Landsat7\\L71046029_02920050705_MTL.txt\\Multispectral"
InPANraster = "C:\\Landsat7\\L71046029_02920050705_MTL.txt\\Panchromatic"
band_index = "3 2 1 5"
arcpy.management.ComputePansharpenWeights(InMSraster, InPANraster, band_index)
ComputePansharpenWeights 示例 3(工作流脚本)
这是在其它工具中使用 ComputePansharpenWeights 输出的 Python 脚本示例。
#Compute the pansharpening weights and use the results in the
#create pansharpening tool.
try:
import arcpy
InRGBraster = "C:\\temp\\rgb.img"
InPanraster = "C:\\temp\\pan.tif"
#Compute Pan Sharpen Weights
out_pan_weight = arcpy.management.ComputePansharpenWeights(
InRGBraster, InPanraster, "3 2 1 4")
#Get results
pansharpen_weights = out_pan_weight.getOutput(0)
#Split the results string for weights of each band
pansplit = pansharpen_weights.split(";")
#Run the Create pan sharpened raster dataset tool.
arcpy.management.CreatePansharpenedRasterDataset(
InRGBraster, "3", "2", "1", "4", "C:\\temp\\pansharpened_raster.tif",
InPanraster, "Gram-Schmidt", pansplit[0].split(" ")[1],
pansplit[1].split(" ")[1], pansplit[2].split(" ")[1],
pansplit[3].split(" ")[1])
except arcpy.ExecuteError:
print(arcpy.GetMessages())
except Exception as err:
print(err[0])
