# Name: EnableIndoorPositioning_example1.py
# Description: Creates the ArcGIS IPS table and feature classes in an
# existing geodatabase
# Import system modules
import arcpy.indoorpositioning as ips
ips.EnableIndoorPositioning(r"C:\IndoorPositioning\ExampleDatabase.gdb")
# Name: EnableIndoorPositioning_example2.py
# Description: Creates an empty file geodatabase and creates
# the ArcGIS IPS table and feature classes
# Set local variables
gdb_path = r"C:\IndoorPositioning"
gdb_name = "ExampleDatabase.gdb"
# Call the CreateFileGDB tool to create a new file geodatabase
arcpy.management.CreateFileGDB(gdb_path, gdb_name)
# Call the EnableIndoorPositioning tool to create the ArcGIS IPS
# table and feature classes in the empty file geodatbase
ips.EnableIndoorPositioning(r"{0}\{1}".format(gdb_path, gdb_name))
