Add Level Variables (Territory Design Tools)
汇总
Adds a new field at the specified level.
用法
  • Added fields will be based on a numeric field from the level below the territory level and will be calculated based on the type of statistic specified.
  • The variable is added to any level above the base or alignment level (0).
  • All numeric fields are supported.
参数
标注 说明 数据类型
Input Territory Solution
The input territory solution.
Group Layer; Feature Dataset; String
Level
The level to which the calculated field will be added.
String
Base Level
The level below the territory level to which the attribute value will be added.
String
Variables
The variables that will be added to the level.
值表列:
  • Statistic Field—The field that will be used for the statistical calculation.
  • Statistic—Type of statistical calculation.
    • Count—The number of values included in the calculation will be identified.
    • Sum—The values for the specified field will be added together.
    • Maximum—The largest value for the specified field will be identified.
    • Minimum—The smallest value for the specified field will be identified.
    • Average—The average of the values for the specified field will be calculated.
    • Median—The median of the values for the specified field will be calculated.
    • Standard Deviation—The standard deviation of values for the specified field will be calculated.
    • Percent of Total—The percentage of each value for the specified field will be calculated from the total sum of the values for the field.
  • Field Name—Valid name of the field on the level where the calculated data will be stored.
  • Field Alias Name—Readable and understandable name of the calculated field.
Value Table
派生输出
标注 说明 数据类型
Updated Territory Solution
The updated territory solution.
Group Layer
环境
Current Workspace
许可信息
  • 基本: Requires Business Analyst
  • 标准: Requires Business Analyst
  • 高级: Requires Business Analyst
