Add Territory Barriers (Territory Design Tools)
汇总
Allows the addition of polygon or line features to prevent or restrict the growth of territories.
插图
Line barriers
用法
  • Line or polygon layers can be used as barriers.
  • New features can be added to an existing barrier.
  • Each level can contain both an impedance and a restricted area.
参数
标注 说明 数据类型
Input Territory Solution
The Territory Design solution layer that will be used in the analysis.
Group Layer; Feature Dataset; String
Level
The level to which the barriers will be applied.
String
Input Barrier Features
Line or polygon features used as a barrier.
Feature Layer
Barrier Type
(可选)
Specifies the type of barrier.
  • Impedance—Limits the growth of territories. This is the default.
  • Restricted Area—Prevents the creation of territories.
String
Append to existing barriers
(可选)
Specifies whether to append or replace the records to the barriers layer.
  • 选中—Appends records to an existing barrier layer.
  • 未选中—Creates a new barrier layer or replaces records in an existing barrier layer. This is the default.
Boolean
派生输出
标注 说明 数据类型
Updated Territory Solution
The updated territory solution.
Group Layer
环境
Current Workspace
许可信息
  • 基本: Requires Business Analyst
  • 标准: Requires Business Analyst
  • 高级: Requires Business Analyst
