Create Territory Level Feature Classes (Territory Design Tools)
汇总
Creates feature classes for a specified territory level.
用法
  • The output point feature classes represent the centers of the features at the base or territory level.
  • The output polygon feature classes represent the boundaries (perimeters) of the features at the base or territory level.
  • The base level can only contain base boundaries and base centers.
  • A Thiessen polygon will be created for the base boundary feature class if a point-based solution is created.
  • The default feature class for a polygon solution is Base Territory Boundaries.
    Base territory boundaries
  • The default feature class for a point solution is Base Territory Centers.
    Base territory centers
  • The polygon feature classes represent boundaries (perimeters) of the features in territory level.
    Territory boundaries
  • The point feature classes represent territory centers.
    Territory centers
参数
标注 说明 数据类型
Input Territory Solution
The Territory Design solution layer that will be used in the analysis.
Group Layer; Feature Dataset; String
Level
The level to which the feature classes will be added.
String
Feature Classes
Specifies the feature classes that will be created at the specified Level parameter value.
  • Territory Boundaries—Polygon features that represent the territory boundaries will be created.
  • Territory Centers—Point features that represent the territory centers will be created.
  • Base Boundaries—Polygon features that represent the base boundaries will be created.
  • Base Centers—Point features that represent the base centers will be created.
  • Line Barriers—Line features that restrict traversal across a line will be created.
  • Seed Points—Point features from which territories are derived will be created.
  • Restricted Areas—Polygon features that prevent the creation of territories will be created.
  • Polygon Barriers—Polygon features that restrict traversal across a polygon will be created.
String
派生输出
标注 说明 数据类型
Updated Territory Solution
The updated territory solution.
Group Layer
环境
Current Workspace
许可信息
  • 基本: Requires Business Analyst
  • 标准: Requires Business Analyst
  • 高级: Requires Business Analyst
