Rebuild Territory Solution (Territory Design Tools)
汇总
Updates the territory solution to reflect changes made to the base level.
用法
  • The input data must be an existing territory solution layer.
  • Territory levels are rebuilt with the correct territory ID.
  • If the parent ID is updated in the base level attribute table, the territory level is not automatically updated to reflect the changes. You must rebuild to propagate the changes to the upper level.
  • The following changes are supported by the tool:
    • Edits to the geometry of the base layer, for example, add, move, and delete.
    • Updates to attribute value; for example, attribute values will be aggregated to the upper level with rebuild.
    • Updates to parent ID.
  • Removing fields is not supported.
  • If territories are manually updated using the Territory Design ribbon tools—for example, Assign and Unassign—the upper level territory will automatically update and you will not need to rebuild.
参数
标注 说明 数据类型
Input Territory Solution
The input territory solution.
Group Layer; Feature Dataset; String
Boundary Mask
(可选)
The layer that is used as a mask to limit the growth of point-based layers.
Feature Layer
派生输出
标注 说明 数据类型
Updated Territory Solution
The updated territory solution.
Group Layer
环境
Current Workspace
许可信息
  • 基本: Requires Business Analyst
  • 标准: Requires Business Analyst
  • 高级: Requires Business Analyst
