Generate Product Layout (Topographic Production Tools)
汇总
Automates the process of producing a layout or map based on a standard specification.
注:
A product data file installer is available for ArcGIS Topographic Mapping. The product files contain predefined layout PAGX templates that can be used for cartographic production.
Learn more about product files
用法
  • The Product parameter options are provided as part of the product data files installation, which contains supported map products and their properties. This is also the source of the list of versions supported for a specified product.
  • The tool will create feature classes and feature datasets in the Input Geodatabase value as it creates the finished layout product.
  • The template layers in the Input Geodatabase value must adhere to the data model of the selected product. For example, if an MGCP Topographic Map (MTM) product is selected, the template must include layers that point to feature classes based on the MTM data model, and the Input Geodatabase value must adhere to the MTM data model.
    If the tool encounters an Input Geodatabase layer with no matching feature class, a warning appears and that layer will include a broken data source in the final layout template.
  • The Preset File parameter is only available when the Output Type parameter is set to PDF or TIFF. You can create preset files in the Export pane when exporting layouts.
  • This tool uses JSON product definitions to generate the specified map product layout. These JSON product definitions are included with the product files and can be updated for custom map products.
    Learn more about the JSON in the Topographic Production Service addProduct operation included with the Topographic Mapping extension
参数
标注 说明 数据类型
Input Geodatabase
The input geodatabase that contains the features for the final map product. The schema of the workspace must match the schema of the product selected.
Workspace
Area Of Interest
A polygon feature layer that describes the processing extent. The feature layer must have only one feature selected or must be a feature class with only one feature.
Feature Layer
Product
Specifies the supported map product that will be used.
  • MTM25—An MGCP Topographic Map (MTM) map product at a 1:25,000 scale will be used.
  • MTM50—An MTM map product at a 1:50,000 scale will be used.
  • MTM100—An MTM map product at a 1:100,000 scale will be used.
  • TM25—A Topographic Map (TM) map product at a 1:25,000 scale will be used.
  • TM50—A TM map product at a 1:50,000 scale will be used.
  • TM100—A TM map product at a 1:100,000 scale will be used.
  • JOGA—A Joint Operations Graphic (JOG) map product at a 1:250,000 scale will be used.
  • CTM50—A Civilian Topographic Map (CTM) map product at a 1:50,000 scale will be used.
  • EVC—An Evasion Chart (EVC) map product at a 1:250,000 scale will be used.
String
Version
The supported versions of the selected product.
String
Output Location
The folder path where the output file will be written.
Folder
Input Rasters
(可选)
The input rasters that will be used if the product requires an elevation guide surround element to calculate the elevation bands and spot height features. If you specify more than one raster, the rasters must have the same cell size, band number, and pixel type. If no raster is specified, the elevation guide data frame will not be processed and a warning will appear.
Raster Layer; Mosaic Layer
Layout Template
(可选)
The layout template that will be used. If no layout template is specified, the default layout template for the product will be used.
Layout
Output Type
(可选)
Specifies the type of output that will be created.
  • PAGX—A layout file will be created. This is the default.
  • APRX—An ArcGIS Pro project file will be created.
  • PDF—A .pdf file will be created.
  • TIFF—A .tiff file will be created.
  • PPKX—An ArcGIS Pro packaged project file will be created.
String
Preset File
(可选)
A file that defines a set of parameter values for the specified Output Type parameter value.
File
派生输出
标注 说明 数据类型
Output File
The template representing the final topographic map.
Layout; File
环境
此工具不使用任何地理处理环境。
许可信息
  • 基本: No
  • 标准: No
  • 高级: Requires Topographic Mapping and Spatial Analyst
