Distance geoprocessing functions
Mit Spatial Analyst-Lizenz verfügbar.
The Distance geoprocessing functions allow you to perform analysis that accounts for either straight-line (Euclidean) or weighted distance. Distance can be weighted by a simple cost (friction) surface, or in ways that account for vertical and horizontal restrictions to movement.
Distance analysis can be performed with the ArcGIS Spatial Analyst extension.
The following table lists the available geoprocessing functions and provides a brief description of each.
Geoprocessing Function
Distance Accumulation
Calculates accumulated distance for each cell to sources, allowing for straight-line distance, cost distance, and true surface distance, as well as vertical and horizontal cost factors.
Distance Allocation
Calculates distance allocation for each cell to the provided sources based on straight-line distance, cost distance, and true surface distance, as well as vertical and horizontal cost factors.
Least Cost Corridor
Calculates the sum of two accumulative cost distance rasters with the option to apply a threshold based on percentage or accumulative cost.
Optimal Corridor Connections
Calculates the optimal corridor connections between two or more input regions.
Optimal Path As Line
Calculates the optimal path from a source to a destination as a line.
Optimal Path As Raster
Calculates the optimal path from a source to a destination as a raster.
Optimal Region Connections
Calculates the optimal connectivity network between two or more input regions.
Geoprocessing functions in the Distance category
In ArcGIS Pro 2.5 and later, the recommended geoprocessing functions for distance analysis are listed in the table above. In versions earlier than ArcGIS Pro 2.5, distance analysis was performed using other geoprocessing functions; these geoprocessing functions are still available in the Legacy Distance geoprocessing function category.
