Apply Building Offsets (Topographic Production Tools)
Zusammenfassung
Aligns, moves, and hides building features or calculates offset values for bridge features based on product specification rules defined in an .xml file.
If this tool is run with a building offset XML rule file, it aligns, moves, and hides building marker symbols based on product specification rules defined in an .xml file.
If this tool is run with a bridge offset XML rule file, it calculates the offset values necessary to properly display bridges at a given location. These values can be calculated for bridge features with line or point geometry.
  • Line bridge feature offsets will be calculated for the width of a bridge based on the overpassing feature that runs through the bridge
  • Point bridge features offsets include the following:
    • The rotation angle of a bridge based on its overpassing feature
    • The position of the bridge if the original position is not coincident with the overpassing feature
Hinweis:
A product file installer is available for ArcGIS Topographic Mapping. The product files contain predefined XML rule files that can be used for cartographic production.
Learn more about product files
Verwendung
  • The feature layers referenced in the rule file must have their symbology defined pursuant to the product specification using ArcGIS Arcade expressions.
  • The layers must have attribute-driven symbology enabled for marker symbols.
  • The tool will create an ABO_Rotation field in the Buildings table if one does not already exist and connect the rotation property of building marker symbols to this attribute.
Parameter
Input Map
The map that contains the layers with proper symbology. This can be a map in the application or an .mapx file on disk.
Map
Rule File
An .xml file containing the offset rules that define how features will be aligned and refined in case of any conflict.
File
Abgeleitete Ausgabe
Updated Map
The updated map with modified building features and symbology.
Map
Umgebungen
Dieses Werkzeug verwendet keine Geoverarbeitungsumgebungen.
Lizenzierungsinformationen
  • Basic: No
  • Standard: No
  • Advanced: Requires Topographic Mapping
