Rule files for building offsets
Lizenzierungs-Portal Mit einer ArcGIS Topographic Mapping-Lizenz verfügbar.
Predefined .xml building offset rule files that can be used for cartographic production by the Apply Building Offsets tool are included in a product file installer available for ArcGIS Topographic Mapping.
The .xml files define the rules for how features are offset.
Achtung:
Modifying these files may result in errors or unexpected behavior.
The following XML example demonstrates the basic structure of a building offset rule file.
<TopographicOffsets title="MGCP_50K" version="10.2.0.0" referencescale="50000">
 <AlignMarkerToStrokeOrFill>
  <MarkerAlignment layer="BuildP - NotBlue072">
   <Queries>
    <Query>
     <Symbols>
      <Symbol>General Building / non-obstruction / intact / generic (point) PS-04693</Symbol>
      <Symbol>General Building / non-obstruction / intact / christian (point) PS-04695</Symbol>
     </Symbols>
    </Query>
   </Queries>
  </MarkerAlignment>
  <StrokeOrFill layer="AquedctL - NotBlue072">
   <Queries />
  </StrokeOrFill>
  <SearchDistance units="Meters">25</SearchDistance>
  <MarkerOrientation>PERPENDICULAR</MarkerOrientation>
 </AlignMarkerToStrokeOrFill>
 <Hierarchies field="HIERARCHY">
  <Hierarchy layer="BuildA - Blue072" value="0">
   <Queries>
    <Query>
     <Symbols>
      <Symbol>Vertical Obstruction / single (area point) P00008</Symbol>
     </Symbols>
    </Query>
   </Queries>
  </Hierarchy>
  <Hierarchy layer="LandmrkP - Blue072" value="0">
   <Queries>
    <Query>
     <Expression>F_CODE = 'AK160'</Expression>
    </Query>
    <And>
    <Query>
     <Symbols>
      <Symbol>Vertical Obstruction / single (point) PS-04512</Symbol>
     </Symbols>
    </Query>
    </And>
   </Queries>
  </Hierarchy>
 </Hierarchies>
 <ResolveBuildingConflicts>
  <Buildings>
   <Building layer="BuildA - NotBlue072">
    <Queries />
   </Building>
   <Building layer="BuildA - Blue072">
    <Queries />
   </Building>
  </Buildings>
  <HierarchyField>HIERARCHY</HierarchyField>
  <InvisibilityField>ISVISIBLE</InvisibilityField>
  <Barriers>
   <Barrier layer="RoadL" orient="False" gap="15 Meters">
    <Queries />
   </Barrier>
   <Barrier layer="RailrdL" orient="False" gap="15 Meters">
    <Queries />
   </Barrier>
  </Barriers>
  <BuildingGap units="Meters">20</BuildingGap>
  <MinimumAllowableBuildingSize units="Meters">25</MinimumAllowableBuildingSize>
 </ResolveBuildingConflicts>
</TopographicOffsets>
AlignMarkerToStrokeOrFill element
The following table provides details for each child element of the AlignMarkerToStrokeOrFill element:
Element
Details
MarkerAlignment
The parent element with queries for the point symbols that will be aligned to nearby lines or polygons.
StrokeOrFill
The lines or polygons that the point symbols are aligned to.
SearchDistance
The distance in meters to search starting from the edge of the point symbol to the edge of a line or polygon.
The example above uses meters as the unit of measurement, but you can specify a different unit of measurement.
MarkerOrientation
Specifies how the point symbol will be oriented relative to the line or polygon. The options are PERPENDICULAR and PARALLEL.
Tipp:
The AlignMarkerToStrokeOrFill element defines values that are used to perform a similar function as the Align Marker To Stroke Or Fill tool. Child elements of the AlignMarkerToStrokeOrFill element are the same as the parameters of that tool.
The Queries child element of MarkerAlignment contains child elements that are used to identify the point symbols that represent building markers.
The following table provides details about the Queries child elements:
Queries
Element
Details
Query
Contains the Symbols elements.
Symbols
Contains the Symbol elements that represent the symbols that will be offset.
This element supports the following attributes:
  • not—Specifies whether the contained Symbol elements are excluded from being offset. For example, a value of true means that offsets will be applied to all Symbol elements except the ones contained in this Symbols element.
  • isGrouped—Specifies whether multiple symbols can be included. Consider the following:
    • The value for the symbols specified must be exactly as they appear in the Symbology table. Adding or skipping values will result in an error. Copy and paste the value from the Symbology table to avoid errors.
    • Values must have a semicolon and space between them when this attribute's value is true.
      Achtung:
      If the text for a value happens to contain a semicolon, the Apply Building Offsets tool will fail when run.
  • useLabel—Specifies whether the label for a building feature can be used instead of a value.
    Tipp:
    If the isGrouped attribute value is also True, the useLabel attribute can be used for groups and a list of symbol values is not required.
By default, these attributes don't appear in the XML and must be inserted. Because they are undeclared, the behavior is that of a false value.
Symbol
The point symbols that will be offset.
      Achtung:
    Tipp:
By default, these attributes don't appear in the XML and must be inserted. Because they are undeclared, the behavior is that of a false value. In this case, the parent element's attributes are applied. If inserted, the child element attributes override the parent's.
Hierarchies element
The Hierarchies element assigns Hierarchy field values to specified layers. These values prioritize layers to be offset.
  <Queries>
   <Query>
   </Query>
   <And>
   <Query>
    <Symbols>
    </Symbols>
   </Query>
   </And>
  </Queries>
 </Hierarchy>
</Hierarchies>
The following table provides details about the Hierarchies element's child elements:
Hierarchies
Element
Details
Hierarchy
The layer that the child elements will impact. The numerical value specified in this element defines the layer's priority when the Apply Building Offsets tool is run and checks the feature's offset. This can impact how the feature is symbolized. Features with a higher value are moved before features with a lower value. A feature with a value of 0 is not offset at all.
In the example above, F_CODE = 'AK160' can be symbolized as a regular symbol or as a vertical obstruction. Vertical obstructions have a value of 0; regular symbols can have a value of 4 or 5 and would be included in the rule file under another Hierarchy element.
Queries
Contains the Query elements.
Query
Contains the Symbols elements and can use the Expression element to filter features.
Expression
Expressions that limit which features are assigned hierarchy values.
And
Combines multiple queries.
Symbols
Symbol
Defines the feature symbology for a building mask according to industry specifications. You can define as many Symbol elements as necessary.
ResolveBuildingConflicts element
The ResolveBuildingConflicts element defines values that are used to perform a similar function as the Resolve Building Conflicts tool. Child elements of the ResolveBuildingConflicts element are the same as the parameters of that tool.
Learn more about conflict resolution and building features
 <Buildings>
  <Building layer="LandmrkP - NotBlue072">
   <Queries>
    <Query>
     <And>
     <Symbols>
     </Symbols>
     </And>
    </Query>
    <Or>
    <Query>
     <Symbols>
      <Symbol>Stadium / non-obstruction / intact (point) PS-04062</Symbol>
      <Symbol>Stadium / non-obstruction / not intact (point) PS-04933</Symbol>
     </Symbols>
    </Query>
    </Or>
   </Queries>
  </Building>
 </Buildings>
 <Barriers>
  <Queries />
  </Barrier>
 </Barriers>
The following table provides details for each child element of the ResolveBuildingConflicts element:
Element
Details
Buildings
The child elements in this element specify the point and polygon building features that may need to be adjusted to resolve conflicts with other buildings or barriers.
HierarchyField
The field that will be checked for a ranking value of importance.
InvisibilityField
The field that will be updated if a building cannot be reasonably offset from other features and as a result, will be hidden from display.
Barriers
The layers containing the linear or polygon features that conflict with buildings.
BuildingGap
The minimum allowable distance between building symbols at scale. Buildings that are closer together will be displaced or hidden to enforce this distance.
The minimum allowable size of the shortest side of a rotated best-fit bounding box around the symbolized building feature drawn at the reference scale. Buildings with a bounding box side smaller than this value will be enlarged to meet it.
The Queries grandchild element of Buildings contains child elements that are used to identify the point and polygon feature classes to check for conflicts with other buildings or barriers.
Queries
Element
Details
Query
Contains the Symbols and Expression elements. The Expression element can be used to filter features in the feature class specified for the Building element.
Symbols
And
Or
Allows multiple queries.
Symbol
The point or polygon feature symbols that will be offset.
