Import Topology (Topographic Production Tools)
Zusammenfassung
Creates a geodatabase topology from a definition .xml file generated by the Export Topology tool in the Topographic Production toolbox.
Both this tool and the Export Topology tool allow you to share and create topologies within different geodatabases. The .xml file contains a definition of a topology, including feature class names, topology ranks, topology rules, and cluster tolerance.
Verwendung
- This tool supports all data models, with a properly configured
.xmldefinition file, and can be used on any feature dataset.
Parameter
| Beschriftung | Erläuterung | Datentyp |
Input Feature Dataset |
The feature dataset in which the topology will be created. The feature dataset must contain the feature classes listed in the Input Topology Definition File. |
Feature Dataset |
Input Topology Definition File |
The |
File |
Abgeleitete Ausgabe
Output Topology |
Output topology created by importing topology rules from the topology XML file. |
Topology |
Umgebungen
Dieses Werkzeug verwendet keine Geoverarbeitungsumgebungen.
Lizenzierungsinformationen
- Basic: No
- Standard: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
- Advanced: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
