Create a rectangular feature
The Rectangle tool creates planar rectangular or square features using the pointer or typed values. This tool is available on the Mapview toolbar with polygon feature layers.
When you use this tool, consider the following:
  • Vertices for 3D z-aware features are assigned z-values based on your current elevation settings.
  • The feature is automatically finished when its location, direction, and dimensions are fully defined.
  • Click the Horizontal / Grid Aligned button to constrain a rectangle orthogonal to the map's coordinates system or the grid for editing if it is turned on. This setting is available on the construction toolbar and on the context menu when you right-click the map.
If the active map is set to a geographic coordinate system, your specified distances and directions are measured using the North Azimuth (0 degrees) system and may produce unexpected alignment or accuracy errors.
To avoid these types of errors, the best practice is to assign the active map a projected coordinate system that matches the coordinate system of the layer or layers you are editing.
Draw or type the length and width
By default, the Rectangle tool creates a rectangle with three pointer clicks. After clicking two locations to specify a corner and a direction, you can right-click the map and type length and width values.
To draw a rectangle with the pointer, complete the following steps:
  1. Add the data and configure the editing settings.
    Confirm that the feature layer you are editing is editable, the coordinate system assigned to the active map is suitable for the type of edits you're performing, and snapping is configured to help you work efficiently and accurately.
  2. On the Map tab, in the Features group, click Edit .
  3. In Contents, click a polygon layer.
  4. Click the Rectangle tool on the Mapview toolbar.
  5. Click the map to create the first corner.
    To type a coordinate location, right-click the map and click Absolute X,Y,Z .
  6. Move the pointer and click the map to specify the direction of the feature.
    To type a direction value, right-click the map and click Direction .
  7. Move the pointer to specify the length and width, and click the map.
    To type values for the length or the width, right-click and click the corresponding command described in the following table:
    Button
    Square New Rectangle
    Click and turn this setting on to constrain the feature to a square. A value typed for the length or width is applied to the remaining side. This button is also available on the construction toolbar.
    Length Height
    Type the length value. If this dimension fully defines the feature, the feature is automatically finished.
    Width Width
    Type the width value. If this dimension fully defines the feature, the feature is automatically finished.
  8. On the Mapview toolbar, click Save All Edits.
    Alternatively, on the ribbon, in the Manage Edits group, click Save All Edits .
  9. On the Edit tab, in the Close group, click Close Edit Mode .
    Optionally, continue editing until you're ready to close Edit mode.
    Alternatively, continue editing until you're ready to close Edit mode.
    Edit Mode is enabled and the Edit tab appears on the ribbon.
Type the direction and size
The Direction/Size dialog box creates a rectangle from values you type for direction, length, and width. To change direction or distance units, click a parameter drop-down arrow.
To create a rectangle with typed values for direction and size, complete the following steps:
  6. Right-click, click Direction/Size , select the units, type the direction and distance values, and press Enter.
    Direction/Size
  7. On the Mapview toolbar, click Save All Edits.
  8. On the Edit tab, in the Close group, click Close Edit Mode .
Keyboard shortcuts
The keyboard shortcuts described in the following table provide an alternative way to run commands for this tool:
Keyboard shortcut
Action
Comment
Tab
Turn Horizontal/Grid Aligned on or off.
When turned on, constrains the feature vertical or horizontal at 90-degree angles.
A
Specify a direction .
Open the Direction dialog box.
L
Specify a length .
Open the Length dialog box.
W
Specify a width .
Open the Width dialog box.
F6
Specify absolute X,Y,Z .
Open the Absolute X,Y,Z dialog box.
Shift and drag
Make the shape a square.
Constrain the shape to a square. Create the first point of the rectangle, press the keyboard shortcut, and drag.
Shift
Turn Square on or off.
When turned on, constrains the shape to a square.
Keyboard shortcuts for the Rectangle construction tool
Back to top
